Soooo, do we really NEED the spring that returns the clutch pedal??
Just as the title says. I started hearing a clicking today when i pressed the clutch in.
After poking around a bit i discovered that one side of the spring that returns the clutch pedal had brkoen off and was rubbing on the assembly causing the "clicking". SO me being the certified mechaninc that i am just removed the little bastard.
Clutch seems to be fine without, but i'm curious as to whether this will cause problems?? Thanks for helping a newb out fellas.
