What should my PTV clearance be
I'm getting ready to put heads on my car and need to know what kind of PTV clearance I need for my set up. My Setup is a Tourqer 2 with a set of LS6 heads decked .030, and I'm running factory head gaskets. Also is the 7.4 push rods I have going to work also?
Originally Posted by PREDATOR-Z
More info on heads needed. .030= 5cc, then better check you PTV
Also what is the LSA and advance (ICL) in this TV2?
Originally Posted by redtail2426
it will be close.I have ls6 heads milled .018",cometic .045 gaskets and a 228/230 on xe lobes and a 112 lsa and i have about .085 intake and .135 exhaust.just check it
Bigger valves on the heads?
CNC Ported Stage 1 GM LS2/LS6 Cylinder Heads
New GM LS2/LS6 243 casting
5 axis CNC machined
Fully assembled
220cc Intake Runner
Intake Flow Rate 305 CFM
Exhaust Flow Rate 235 CFM
New 2.000 intake valves / 1.550 exhaust valves
GM Valve Seals, Retainers, and Locks
It "should" fit with stock gasket. But better measure.
