Head gasket options for LS7 heads???
You can go stock, or check out cometic. Thats what I'm using, and they're very nice, and seal very well... http://www.cometic.com/domesticauto.aspx
Originally Posted by Ferocity02
I used the same exact ones, 4.160" bore from Cometic. They worked great!
4.160"
Why so large???
I figured everyone (at least the 4.125 bore crowd) was using 4.130...
Originally Posted by SideStep
What are the head gasket options for LS7 heads??? (bore dia, compressed thickness??)
Side Step... Flatout Gaskets makes a mls gasket for the LS7 also...I think they will also do rubber coated copper in whatever thickness you want.
4.160"
Why so large???
Why so large???
Originally Posted by Fraser@SpeedInc
You want expansion room for the gasket, and for firing ring to be within size of the combustion chamber. OE LS7 MLS gasket is 4.150"
Thanks for the good explanation =D Everyone learns something new everyday.
Best Regards,
Adrian Mejia
What kind of NA compression can the stock gaskets hold?
Would they be ok on a 14:1 or 15:1 High Compression Race Motor?
I am thinking along the lines of LS7R here...(I have to ask after seeing the LS7R at Chevy's RevItUP driving event)
EDIT: Off topic, but that LS7R had Katech stuff ALL over it. Heads, valley cover, some weird looking coil set-up for the spark plugs(two black boxes instead of 8 coils), dry sump, it was fraking sweet to finally see some Katech products in person...
They also started the C6R they brought with them, but I was told it had just an open exhaust LS2 with some sort of cam. It sounded high compression though...
Back on topic>
Back on topic>
