efi live help
Old 07-15-2007, 10:31 AM
joe'sls1's Avatar
Default efi live help
im a new user to efi live and have had no sucsess tuning i have a 1998 to 2002 conversion with the van map programed in. the car seems to run fine but i can tell that its running a little rough.
i tryed advncing timing by 3 i upped the fuel by 3 in the high rpm and droped it by 2 in the lower. i also added a little dwell by 1 milli and upped the maf tables by 1 it still seems to run the same but a little more responsive with low end when i do the same tune as above with out maf and adding fuel to the table at low and high smothining the peeks as much as i can i get a car with less tourqe and more spin in the mid end.
if you have any tuning tips for me let me know
i have ls1 with all ls6 blotons intake 85mm trottle body paceseter header and y pipe k tech rod bolts slp oil pump and chain tr55 plugs and wires full slp induction ram air turn one power stering pump
Old 07-15-2007, 06:18 PM
zapp168's Avatar
I did the same swap. How did the car run before you swapped? Was it tuned for your mods? Which tune did you use as a base tune? I initially used a tune off of holdencrazy which migrated a 99 tune to a 2002 Operating system. My car actually ran better with that tune than it did with a professional tune. I just needed to tweek the idle, and lower the timing a little cause of my turbo. If your car was tuned before you can migrate the old settings to the new tune, mostly VE, spark, and MAF.
Old 07-15-2007, 09:30 PM
Doc
Doc's Avatar
You need to spend more time with the scanner. There are many preconfigured MAPs that will help you out. Using the bidirectional controls or a RR give the car what it wants.
Old 07-16-2007, 10:23 AM
zapp168's Avatar
As I mentioned to you, the 2002 tune does not have EGR provisions. If you still have your EGR installed that may cause issues
Old 07-19-2007, 06:07 PM
joe'sls1's Avatar
egr is gone the car has moderate power but should be showing more gains but runs like stock
Old 07-19-2007, 06:30 PM
vaticano's Avatar
i agree
Old 07-19-2007, 07:17 PM
ZL1Killa's Avatar
you need to re-word this. do you have a wideband? advancing timing in what tables? fuel in what tables did u change? ...whats this dwell table?
Old 07-19-2007, 07:22 PM
LS1TECH Sponsor
foff667's Avatar
Spark dwell
Old 07-19-2007, 10:37 PM
Shallow Bay's Avatar
Can you post the tune?
Old 07-20-2007, 09:42 AM
wait4me's Avatar
you say 98 carmaro? Or 98 truck.... If you are doing a swap to a 2002 pcm with a Camaro, then you DONT use the Van file. If you are a truck that is the only time you need to do that as your 98 truck was the black vortec pcm.
Old 07-20-2007, 03:47 PM
Eurospec2's Avatar
hmm i am pretty sure that in order to make the 98 fuel guage work you have to segment swap in the van fuel segment
Old 07-20-2007, 04:47 PM
Doc
Doc's Avatar
If it is a Fbody. Where is the OP? He never said what he has this LS1 in.
Old 07-20-2007, 06:15 PM
Eurospec2's Avatar
You are absolutely correct sir! I suppose I shoudnt assume such things
