SFC removal: Dremel?
Old 07-15-2007, 12:34 PM
OldeSkool's Avatar
Default SFC removal: Dremel?
I was looking at my SFC's trying to figure out a good way to remove them.
Can a dremel tool (or similar) do the job? Would I want to use a grinding disc or a cutting disc?
Old 07-15-2007, 04:09 PM
Tenured Member
SMOKY's Avatar
Why do you ant to remove them? 3" cutoff wheel or grinder will work the best.
Old 07-15-2007, 05:41 PM
subtlez28's Avatar
You can buy "real" grinders for $30-50. I would think a dremel would take alot of time and discs.
Old 07-15-2007, 05:47 PM
revtime's Avatar
You will get frustrated rather quickly trying to use a dremel to cut them off, it will take weeks.
Buy a grinder and get a cut off wheel to replace the grinding wheel and it will go much quicker.
Of course a cutting torch will get you out of the garage in about 20 minutes.
Old 07-15-2007, 09:30 PM
Ironhead's Avatar
You'll only need a grinder to finish off the sharp stuff left when the job is done.
Most of the work will be done with a Sawzall. Stock up on heavy duty blades. I did this very thing just last winter.
Old 07-15-2007, 10:09 PM
z28bryan's Avatar
I'm guessing he wants to get classed under Street Mod SCCA class in autox?
Old 07-16-2007, 10:37 AM
Moderator
jimmyblue's Avatar
I recommend a 4-1/2" angle grinder, you can use the wheel
edge-on for taking out the beads and then dress it clean with
the face. Harbor Freight ones are under $20 on sale (be sure
you get the one that works with standard abrasive wheels,
they sell some that are "orphans" too).
Old 07-16-2007, 12:34 PM
OldeSkool's Avatar
I just sorta wanted to stay away from something big and fast like a grinder. I'd really hate to tear into the sheet metal.
Quick Reply: SFC removal: Dremel?
