6.0 truck intake man vs LS6 intake
I read somewhere the 6L truck intake was as good as the LS6. Since on my application hood clearance is not an issue I could save some money by getting a used truck intake. Has anyone here dynoed or flow tested the 6L truck intake?
Re: 6.0 truck intake man vs LS6 intake
From what I've seen, the truck intake isn't quite as good as the LS6. I'm not sure if that was a 6.0L truck intake or not, though.
I would also tend to think that the 6.0L truck intake is designed more with low-end torque in mind, so it probably gives up a bit of HP in the upper RPM range...
