Bled the clutch and still hard to shift at high rpm's?
Old 07-15-2007, 07:13 PM
me_eat_rice's Avatar
Exclamation Bled the clutch and still hard to shift at high rpm's?
I bled my clutch with a friend, did it 6 times...Then I went for a test drive(more clutch pressure and shifted great) and then shifted at high rpm's and then it was still very hard to select a gear (required a lot of effort to get it into gear). Can anyone help me out on what is going on here? thanks
Old 07-15-2007, 07:36 PM
SSTYCOON's Avatar
I' ve had the same problem for 2 years!!, I'm racing next weekend and I'm very desparate. I've bled my hydraulics 50 times. I'm thinking my master is bad, I got a new 01-02 slave ...HELP US!!! I cant put it in gear until the pedal is to the floor. and I hear a leaking air noise from the master when I push it in. HELP I don't know if its the cause of it.
Old 07-15-2007, 07:38 PM
yea this really sucks, im guessin our masters are done, but hopefully a hack helps us out here
Old 07-16-2007, 02:51 AM
blk00ss's Avatar
Master's are probably fine, but I HIGHLY suggest the adjustable master cylinder mod! Worked wonders on my car.
Old 07-16-2007, 09:07 AM
black01_WS6's Avatar
you need the drill mod. I had the problem, did the drill mod and it took care of it. Take the whole master out to do it, then wrap the master lines with some thermal wrap.
Old 07-16-2007, 09:09 AM
brad8266's Avatar
if you havent done the drill mod you need to do that
Old 07-16-2007, 04:06 PM
ae13291's Avatar
Drill Mod!!!!
Old 07-16-2007, 04:30 PM
PowerShift408's Avatar
Drill mod, I'm doing it to my car tomorrow because I'm having th exact same problem. It's frustrating, but this should be the remedy.
Old 07-16-2007, 05:09 PM
SSTYCOON's Avatar
I'm gonna try that
Old 07-16-2007, 09:22 PM
do i have to pull the tranny??? (please say no!)
Old 07-16-2007, 11:04 PM
studderin's Avatar
no ..
Old 07-16-2007, 11:46 PM
DarkCloud's Avatar
drill mod.. and adjustably mc mod.. it is so easy.. and helpful.. it would be a waste not to do it.
Old 07-17-2007, 10:56 PM
Disturbed Bird's Avatar
is it a big noticable difference? i dont seem to have that problem it is harder than my friends 07 gt but i shift hard so i dont realy notice. and if i do it will it feel like a 07 gt? just wondering b/c they seem really smooth to me.
Old 07-18-2007, 12:47 AM
Tom01ss's Avatar
This may sound stupid but what are you guys using to bled the clutch.since it's recessed I'm just curious when I need to bled mine after I doing "the change"-clutch
