help...
Originally Posted by slowassta
lol...
No, its using the stock style pcv
if it remain the same or loosing slightly its mean because of your high rev.
try to deleet the intake to throttle oil breather and use an valve cover breather, it could help alot. i did that
i hope this could help other wise take it to the nearest work shop ,let them check it so at least you can sleep well if you know the problem (probably your high rev ).
