Edelbrock Race Headers...
Who has 'em and how was/is the whole experience? Reason I'm asking is because I can get them pretty cheap at work....and the search function is crapping out as usual.
Here's the web page:
http://www.edelbrock.com/automotive_...ers_race.shtml
They look freakin awesome, and I bet the SS version could rival Kooks... maybe. I'm gonna need some input on that one. Check out the collector!! There's a nascar style collector spike inside.
GM High Tech recently put them in a TA:
http://www.gmhightechperformance.com...tallation.html
I can get 20% off the price at Advance...which is pretty awesome to begin with because we push Edelbrock parts hard! Inputs please!
Ive got the Ti-tech coated ones with the slip on collectors, and the fit is excellent. The passenger side slips in from the bottom with no issues at all. The drivers side slides in from the bottom, however, you'll need to pull the steering shaft, but it fits back in from the top with no problem. The only thing I didn't do, was to put some kind of sealer on the tubes where they slip into the collectors. You may or may not have leaks there if you don't sel them. The y pipe fits nicely, and the ground clearance is excellent all the way from the headers to the back of the y pipe.
Impressive. That looks like about the same clearance as the Pacesetter Y pipe, but only without the flat spots. MAN!!..If only I had known about these dudes when I purchased my PaceSetters a long time ago. None of the venders offered them at the time, so I was clueless.
Are yours ceramic coated, Stainles steel, or that tri-tech (or what ever its called)?
Also, hows the merge look inside the Y?
It might just be the camera angle, but doesnt the collector have a spike in it?
Oh I would definately go with the edelbrocks if I could do it all over again. If you want to get some without shipping costs, go into Advance Auto near the last day of the month and ask to get a set priced... ask the store manager... then offer to buy them right then if he would give you 20% off. 90% of the time he will do it. If he tells you that he cant do it then tell him you're just going to get them from summit or jegs. That would probably work.
Im sure the edelbrock tucks well but one thing to keep in mind is that thecars that came with the ground effects sit higher.
Also, most longtubes tuck the same. I have installed hooker, jet hot, pacesetter, and flowtek. All of them tuck so high that you cant even hook a straight piece of pipe to them without it hitting the rib on the floorpan on the driver side. Thats the reason for TSP making their y pipe adjustable and the others putting the flat spots in theirs.
Originally Posted by studderin
even the weld on standard collector you have is 3.5?
looks like they tuck nice, I dont know what LT to get.
