Which heads for boosted engine?
Old 07-15-2007, 10:12 PM
KWIKKAR's Avatar
Default Which heads for boosted engine?
Should one go with 72cc heads or 66cc heads or Ls6 heads. i was reading in another post that if you dont run atleast 14psi + 72cc is over kill. Is that true????
I plan on only being around 600rwhp maybe 700 in the far future.
Stock Ls1 for me.
Old 07-15-2007, 11:02 PM
HAMRHEAD's Avatar
I would go with the 72cc heads
Old 07-16-2007, 01:44 AM
Jimmy P's Avatar
For a turbo setup, I would recommend going with the 72cc heads to lower that compression as much as possible.
Old 07-16-2007, 03:55 AM
2MuchRiceMakesMeSick's Avatar
I went with AFR 225 72cc on my setup
Old 07-16-2007, 04:05 AM
Shorty Director
VINCE's Avatar
So did I..
Old 07-16-2007, 04:28 AM
NAVY's Avatar
I think 225 or more ( 235 , 245) CFM
Old 07-16-2007, 04:45 AM
Websy21's Avatar
I too am interested in your opinions, I am going to run a stock block blower set up for now until I can afford to build a motor. I thought to just bolt on some 6.0 heads while I was in there changing the cam. Since you can get used one's cheap. This would effectively lower CR and should extend motor life, maybe even warrent 10-12psi. Ok 10psi max, do you think it would be a waste of time to bolt on unported stock 6.0 heads, a guy could always give them a quick hand polish. I know, no digrinder dammit. What do you guys think? Not trying to hijack there bud, just thought this could help a little. If it means anything from my research so far I would definely go 72cc if I were you. Thanks guys!
Pathological Modifier
Ryan K's Avatar
Originally Posted by VINCE
So did I..
Me Too!
Old 07-16-2007, 05:30 AM
JMBLOWNWS6's Avatar
Same here 225's 72 cc
EPP
EPP's Avatar
Smile
Stock Ls1 for me.
With your future APS twin turbo, I'd go with the 72cc heads. Bob
Old 07-16-2007, 06:38 AM
NA$TY-TA's Avatar
72cc on my last 317 casting heads and my new heads
Old 07-16-2007, 08:05 AM
KWIKKAR's Avatar
Ok 72cc heads it is. thanks
Old 07-16-2007, 08:01 PM
slowbrakiller's Avatar
anyone need 317 heads?
Old 07-16-2007, 08:13 PM
cablebandit's Avatar
i got dart 62cc 9.27:1
Old 07-17-2007, 10:33 PM
Red99C5's Avatar
Stock Ls1 for me.
That's what I have been told by a guy that has installed hundreds of F/I. He also has a LS7 Z06 running 10.5:1 compression and was making nearly 900 RWHP before he tuned it down to 800 RWHP.
I put some 317 heads on my maggie motor, and lost power. I'm going back with something with some compression. If I was going to run a turbo with lots of boost, then I would go with the larger chamber on a small inch motor.
Old 07-18-2007, 07:58 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,096 Likes on 720 Posts
Must be a lot of dish on those pistons...
Old 07-18-2007, 09:33 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
stock 6.0L 72cc heads working fine for me
Old 07-18-2007, 09:40 AM
Fireball's Avatar
Mine are 60cc and similar compression
Old 07-18-2007, 01:21 PM
bhz28's Avatar
I am going to be using 65cc and getting 8.7:1 comp
Old 07-18-2007, 02:18 PM
-32cc wisecos. I love the Wisecos..Brian Nutter is the MAN and knows pistons inside and out
Quick Reply: Which heads for boosted engine?
