Need input on PCV delete system...
Old 07-16-2007, 06:02 PM
2QUICK4U -WS6's Avatar
Default Need input on PCV delete system...
I'm experiencing lots of smoke during hard acceleration and small amounts of smoke during idling. I have all bolt-ons, full exhaust, MS4 cam swap with the 'all goody' package. The cam swap has only 5k miles so I don't think the valve stem seals are gone yet, but concidering the possibility.
Any input or suggestions would be greatly appreciated.
Thanks.
Old 07-16-2007, 06:38 PM
99TransAmLS16Spd's Avatar
Sounds like we have the same problem with a very similar setup.....
I highly doubt it's the seals, the shop that did my cam swap told me it was dumping smoke on the dyno. They suggested I may have a bad compression ring.....I'm not to sure if I buy into that or not. The engine is not fresh with 85k miles, but I would hope the rings lasted longer than that. I have never ran nitrous through it,messed with the rev limiter, or overrevved by putting it in the wrong gear since I have had the car the last 25k miles. But besides that point, I have a new set of heads I need to install, and have considered foing the ls6 pcv conversion. The only think I don't like about it is "some grinding to the block may be required..."
Old 07-16-2007, 07:19 PM
I highly doubt that it is a compression ring because compression check and leak down test come out perfect!! I only have 60k on motor!! One thing if it were the rings then expect smoke all the time, especially when in the throttle!
But that is one reason i think the valve stem seals, but doesnt smoke on start up!?!?!
Old 07-16-2007, 07:20 PM
Thanks for the help!!!!!
Old 07-16-2007, 08:53 PM
3.4camaro's Avatar
slap a breather on that ho and change your oil every 3000 miles. No more oil consumption and no more ugly exhaust smoke.
Old 07-16-2007, 09:14 PM
black01_WS6's Avatar
well I only smoke at WOT, and it is bothering me. I don't know if I should try changing the heads, or just buy a new shortblock.
Old 07-17-2007, 12:43 AM
3.4camaro's Avatar
changing the heads to stop smoking? BREATHER.
That's like moving to a new house cuz yours is dirty lol.
Old 07-17-2007, 02:03 AM
85ta383's Avatar
agreed with above.. put a breather on the pass side. i ran a line with a pcv valve from the driver side to the pass side valve cover. stopped all my smokin!!
love that quote above
Old 07-17-2007, 12:31 PM
3.4camaro's Avatar
I HAVE A BELIEEEEEEEEEEVA!!!!
Old 07-17-2007, 12:42 PM
Okay, so you're telling me that I need to do the PCV delete system and if so, what parts do I need? Or do I just need to try a search?
Thanks for all the help.. I really appreciate it.
Old 07-17-2007, 01:08 PM
99blancoSS's Avatar
https://ls1tech.com/forums/generation-iv-external-engine/691509-breathers-pcv-bypass-etc.html
Old 07-17-2007, 07:53 PM
Originally Posted by 99blancoSS
Thanks guys for all the help I really appreciate it!!!!
Old 07-18-2007, 11:05 AM
Which one would be more effective, using the breather or catch can method?
Old 07-18-2007, 12:38 PM
99blancoSS's Avatar
Breathers will vent the fumes into the engine compartment which could give you an odor in the car. In addition they can be a little messy if not seperating oil and fumes. The catch can with the restricted line is suppose to eliminate the fumes. Breathers are a lot cheaper. The catch can with the breather seems to be a good design, dont have my car running right now I'm iun the middle of a h/c swap.
