Another carb LSx question
Old 07-16-2007, 11:35 PM
JASON 77's Avatar
Default Another carb LSx question
Lookin to do a LSx carb conversion in my 95 Z28, maybe a 408. Are there any problems runnin this 408 with a carb and MSD box? i remember Timmy Tostos having issues with his, is the issues fixed or was there only issues with certain cranks available? any all info, pics greatly appreciated. thanks Jason
Old 07-17-2007, 05:45 AM
stevemilz's Avatar
Why not get the distributor setup?
Old 07-17-2007, 10:23 PM
justin b's Avatar
i had a carb intake on my asa cam 6.0,it had edelbrock ignition wich was not very tuneable,i sold it,bought a 6ls ignition for my new 404,it is programmable with software from msd,check it out on their website.i went with the 6ls rather than buying a dist kit because the 6ls does the same thing a digital 6 does for almost the same money.
Old 07-17-2007, 10:27 PM
justin b's Avatar
not to mention that dist kit is expensive!!!!
Old 07-18-2007, 12:02 AM
GOaT Cheese's Avatar
I would do a distributor, and a pro-billet.
Old 07-18-2007, 12:45 AM
CoozePoodle's Avatar
I would youse Tacos.
mmm tacos
Old 07-18-2007, 06:50 PM
mmm tacos
Nice contribution to the thread poop-diddle.
Old 07-18-2007, 09:02 PM
justin b's Avatar
who sells the dist kits,and how much? do you have to have a special cam to drive dist?or is it driven another way?just curious.
Old 07-18-2007, 11:54 PM
G.M., you can buy a front cover straight from G.M. that uses the standard small/big block distributor. That is if you don't mind your Chevy having a front mounted distributor.
Old 07-19-2007, 12:58 PM
s.o.m.SS's Avatar
That is the route I am going with my 408. Even though it will look like a little ford under the hood it'll be different.
Old 07-19-2007, 09:34 PM
justin b's Avatar
ok,but what drives the distributor? the cam?it would surely look like a ford with a carbed victor jr intake,it looks almost like the super victor for 351w.and the header port spacing is similar too.
Old 01-12-2008, 02:01 AM
MIEric's Avatar
The exaust port spacing is the same...you can use the same headers if you swap the flanges.
Old 01-12-2008, 07:34 AM
forcd ind's Avatar
i remember someone was using the carb/msd box, and found out the starter was not spinning the engine fast enough to operate, but once they replaced the bat., it was ok
Old 01-12-2008, 07:56 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Subscribing
I'm going this route with my CETA when it's back together
