New LS1 Owners - Newbie Tech - Code question?
View Full Version : Code question?
Juicedz28
07-17-2007, 09:39 AM
Every once and a great while i get a light that pops up on my dash. I don't recognize what its relating to. I checked my repair manual and couldn't find a place where it described what these symbols mean. The symbol that pops up is a square with an arrow inside pointing down towards a low level of some kind of fluid. As i stated i don't know what its relating too. Any help is greatly appreciated. Thank you :bang:
2001NBMZ28
07-17-2007, 11:44 AM
Low coolant.
Juicedz28
07-17-2007, 12:47 PM
Thanks for the reply. I always check my coolant. But now that i think about it i did a throttle body bypass yesterday and some coolant came out. Thanks for the reply.
1SPRY99
07-17-2007, 12:55 PM
The Man Is Correct. Mine Came On After Changing The Thermostat.
2001NBMZ28
07-17-2007, 12:56 PM
The sensor goes bad all the time. If it keeps giving you trouble and coolant is fine you'll have to replace it, or disconnect it to keep the light off like some do. My car didn't even come with one.
Juicedz28
07-17-2007, 01:25 PM
Wow. Thanks. I didn't think so. I always check my fluids... so its a sensor for the thermostat?
2001NBMZ28
07-17-2007, 01:33 PM
Just monitors the coolant level - it's on the radiator a few inches below the radiator cap. If I'm correct GM took them off the F-body starting with the '00 model.
killerinparadise
07-17-2007, 02:04 PM
yeah mine pops on at least once a day on start up, I can turn the car right back off and then back on and it's gone, coolant level is fine I heard that the sensor is just gehy
Juicedz28
07-17-2007, 02:20 PM
Thanks. Yeah every great while mine pops up and i didn't know what it meant. Kinda freaked me out. So i would always check my fluid levels. But no drastic levels.
six_string_wiz
07-17-2007, 04:08 PM
Yep what all the others said.I unplugged mine completely.It came on one day after I drained my coolant and put fresh coolant in.I was on a mission to get rid of that light.
