What trans fluid are the big boys running
Old 07-17-2007, 12:27 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Default What trans fluid are the big boys running
I ran B&M Trickshift with the blower and it was fine. Are most of the big power folks running the tractor stuff, type F, or Trickshift?
Old 07-17-2007, 12:45 PM
Navy David SS's Avatar
Just running normal auto ATF from Shell. 4 years without any problems (so far).
We have a shop Mustang, and couple of tranny builders suggesting an oil from John Deer.. suppose to be great.. I will be trying it out soon as the tranny needs its next oil change.
David
Old 07-17-2007, 04:41 PM
427's Avatar
Mostly tractor oil here. Not sure if its better, but the trans guy wants it, so he gets it. It does seem slightly cheaper than ATF, for a benefit I can see!
Kurt
Old 07-17-2007, 05:29 PM
Turbo LS1 SS's Avatar
mobil 1 atf
Old 07-17-2007, 05:30 PM
BLNLS1/RX7's Avatar
Mobil 1 ONLY.
Old 07-17-2007, 05:34 PM
Z8'S's Avatar
John Deere Hy-Gard
Old 07-17-2007, 05:47 PM
Moderator
FANTAZ28's Avatar
i dont use anything, less drag on the rotating mass
Old 07-17-2007, 05:56 PM
kp
kp's Avatar
Whatever cheapo dexron i have laying around, I'm my trans guy and thats what I recommend to myself
Old 07-17-2007, 06:22 PM
SuperZ's Avatar
I was told to run Type F with my TH-400.So thats what Im running.Is there any bad sides to type F?Id like to know the specific name and weight of the John Dear stuff
Old 07-17-2007, 06:28 PM
DanZ28's Avatar
Rossler told me not to run straight type F fluid, said i could mix it with dexron though. I just run trick shift in my Th400. may be overkill, but WTF.
Dan
Old 07-17-2007, 06:55 PM
Z8'S's Avatar
long thread but good read ....enjoy
http://www.theturboforums.com/smf/in...?topic=58907.0
Old 07-17-2007, 07:21 PM
frcefed98's Avatar
My TH400 builder said Dex and stay the hell away from Type F...so Dex it is.
I have heard tons of good reviews by guys running John Deere Hy-Gard on turbomustangs tho....
Old 07-17-2007, 09:54 PM
LS1Tech Co-Founder
Oh... where to get tractor fluid on the North Side of Chicago... Thanks for the link Chris, that was good reading.
Old 07-17-2007, 10:08 PM
SuperZ's Avatar
Yea I read all 9 of those pages!!Good stuff.Looks like the stuff to get if you do the tractor stuff is High Gard John D or High Tran CASE.I guess it does make shifts firmer and holds heat well.Anyone know if it wears any different on the trans???
Old 07-17-2007, 11:57 PM
NA$TY-TA's Avatar
Originally Posted by Z8'S
John Deere Hy-Gard
Same here... Ran Type F for a while... Trans would get warm quick on the brake...
The tractor fluid keeps the heat down quite a bit...
Ill be adding a Fan on the Trans cooler for this YR.
Old 07-18-2007, 01:55 AM
SuperZ's Avatar
I was reading that there are two different Hy-Gards or maybe it was the Hy-Tran.Any way I read that there is a regular and high viscosity.Which one do you guys run in your th400s and PGs??
Old 07-18-2007, 03:31 AM
DMH Fabrication's Avatar
I use the tractor fluid since thats what Rossler suggested and haven't had any problems.
Old 07-18-2007, 06:06 AM
engineermike's Avatar
Regular old Dex in my TH350. 4-5 years pulling 133 - 146 in the quarter plus countless street miles with no issues.
Mike
Old 07-18-2007, 07:16 AM
smokinHawk's Avatar
so what grade tractor fluid? or is there only one available
Old 07-18-2007, 04:30 PM
TwnTrboCE's Avatar
We run the cheapest stuff Walmart sells. Super Tech dex 3. Have since day 1 with no issues.
Quick Reply: What trans fluid are the big boys running
