GU5 On door. Any idea?
That would be a funny prank. Someone asks a basic, simple question, then keeps asking it over and over as people keep telling him the answer over and over. Whoever gets the most correct answer posts wins. So far, Juicedz28 is up to 5 correct answers in the first page of his post.
Here. I'll add to his point total: The GU5 RPO code means you have a gear ratio of 3:23.
[QUOTE=Juicedz28] Suggestgions?? i just told u what it means, and yes that code is on my door, but incase ur not sure, u could always do a poll!!!
it does infact mean 3.23s! I know this for a fact as i have looked up every code on my door!
So any suggestions.? Does yours say gu5...
[QUOTE=gyrene2003]
Suggestgions?? i just told u what it means, and yes that code is on my door, but incase ur not sure, u could always do a poll!!! I vote for a poll
no really GU5 means its a 3.23 rear gear
No problem, they're just kidding you. BTW, my door says GU2 because it originally came with 2.73's, but now has a 3.42 complete rear out of an M6 car. So sometimes the codes don't help identify what's actually in the car.
Instead of pulling the rear cover visit www.f-body.org/gears/ first and print out what it says for 3.23's - then match it against your RPM on the highway.
Thanks. And thats very true. What would be the correct way to check. Counting the teeth? And if yes. How many is equal to what? Thanks for the help.
Count the ring gear teeth. Then count the pinion gear and divide the two with the ring gear first. That will tell you your gear which is the best way to find out what you have.
