Installed Lt's & more need a tune?
Old 07-17-2007, 01:03 PM
Kanes2413's Avatar
Default Installed Lt's & more need a tune?
just did basic bolt on's Lt's ORY catback. The car runs rough and sounds odd. I was planning on a tune but most places are busy for a few weeks and no one around seems to have the hardware. What kind of problem am i running into and what place sells stuff for tuning my 99 ls1 and how hard is it tune yourself?
Old 07-17-2007, 01:16 PM
ZL1Killa's Avatar
your car is gonna sound way different and you are going to hear vibrations and noises that you normally don't hear. you are going to want a tune. for a 99 ls1 you can get EFI LIVE (www.efilive.com) or HPTuners (www.hptuners.com)
i use efi live it costs anywhere from 500 and up to get the software
Old 07-17-2007, 01:21 PM
RooRnZ28's Avatar
yes, the car will run rough and you will go thru gas faster until you get a tune. it is a night and day difference
LS1TECH Sponsor
foff667's Avatar
Mine ran perfectly fine after I threw on Headers & an ORY...ran like that for ~4 1/2 months without issue other than having the ses light blaring at me. Check to see what codes you are getting, if its running rougher than normal you might be seeing a p0300 missfire code which would lead me to think its a plug or wire issue, possibly just a loose wire, or a cracked plug.
