Western Members CA, AZ, NV, UT, CO, NM, HI
Two Exhaust Questions...
Old 07-17-2007, 03:18 PM
93redBIRDman's Avatar
Default Two Exhaust Questions...
I have a 99 Z28 m6 and want some shorty headers ONLY BECAUSE I AM IN Ca. Here's my questions. Would it be a better bargain to just buy some 01-02 stock manifolds (known to flow decent) and put them in place of my manifolds? Would they be a direct replacement and fit up to my y pipe etc? OR should I go with hooker or JBA shorties? I looked on Hooker's site and it only lists 98 LS1's for their shorties. I'm assuming the 98 shorties would fit on my 99 car right??
Like I said, I've read the 01-02 manifolds are about as good as shorties, so maybe I should just go with those...
Old 07-17-2007, 03:24 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
save money and just get the newer manifold. IMHO shorties are outrageous in price and down on power for what they are.
Old 07-17-2007, 03:35 PM
Yea. I'm wondering if the 01-02 manifolds would bolt right up to my motor without having to customize anything. It'd need to fit directly up to my stock y-pipe...
Old 07-17-2007, 03:37 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well the head design hasn't changed as far as exhaust ports go. I think you would be ok in that arena.
Old 07-17-2007, 03:41 PM
thanks for the info, anyone else ever put 01-02 manifolds on their 98-99 LS1?
Old 07-17-2007, 03:43 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Lots of people have. I bet if you ask this same question in the California section. You will get your answer in a matter of 30 minutes.
Old 07-17-2007, 03:47 PM
move me, Oh mighty moderator
Old 07-17-2007, 03:49 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Will do!
Old 07-17-2007, 03:50 PM
99NMB's Avatar
You are going to have to get the 01-02's y pipe and cats, on the 01-02's the cats were directly after the manifold, on the 98-00's the passengers side cat wad welded in down the pipe about 18 inches.
Old 07-17-2007, 03:51 PM
i knew that about the y-pipe, but just because the cats are in a different location that means i have to change y-pipes to the 01-02? That changes the fitment? weird
Old 07-18-2007, 12:23 AM
97ssCDB's Avatar
I have a set of 02 manifold if you need them, Im in the bay area. Let me know.
Old 07-18-2007, 01:47 AM
Almostryan3's Avatar
of you need the back half of the Y pipe I believe nine finger has it....
Old 07-18-2007, 11:51 AM
what do you mean by the "back half" of the y-pipe?
Old 07-18-2007, 12:13 PM
FastrDamnit!'s Avatar
Remember 01-02's didn't have EGR, since you want to stay legal for smog that might be an issue.
'00's also have the better exh. manifolds AND had EGR, might want to consider that.
Old 07-18-2007, 01:48 PM
Thanks for the info!! That helps a lot! So, if I bought a used set of 00 manifolds/y-pipe, would everything bolt up perfectly just how it is now and have good fitment to my already stock exhaust?
