need help stall converter
i just got a tci ssf 3500-3800 it seems like the car runs like crap now. I really dont know how it should run. Maybe it is rite an i need to get sumthing else with it. rite now i got lid,S3 ported throttle body, Hypertech power progammer 3,throttle body spacer,throttle body bypass,Edelbrock Exhaust
flexs lite trans cooler,pace setters ceramic coat LT header an Off Road y pipe
T C I super street fighter 3500 3800 stall converter, how does it seem slow what did i do wrong please help brand new to LS1
When I first installed my SSF 3500 stall converter into my car, I noticed the car felt sluggish around the 2-3 shift at low rpms. This was especially noticable when I was pulling away from lights, etc. It felt like the car was falling flat on its face. Using HP Tuners, I tried to tune out this problem (changing shift points, etc) with no luck. Until someone told me about a table in HP Tuners regarding torque reduction. After zeroing out this table the problem disappeared immediately. I don't have my laptop with me right now so I can't tell you the exact name of the table that might be your problem. Perhaps someone else can chime in.
LS1Tech Administrator
Received 1,492 Likes
I think the post above is referring to Torque Management. Some cars have issues with this after a converter install. Seems to always be worse on the '01/'02 cars, in my experiance.
Originally Posted by staringback05
it is a computer issue usually, when installing a stall you need to have a retune...theres not much else to it
It's hit or miss really.
Originally Posted by laydlow69
is it hard to do the hp tuner yourself is it the same as dyno tuneing
The table that I zeroed out was the Spark Retard vs Torque Reduction table. When I installed the aftermarket stall the PCM thought something was wrong and rolled back the timing. This is what was causing my car to "fall flat on its face". Once I adjusted this table the problem totally disappeared. Hope this helps.
Get what? HPTuners? You could just find a shop in your area that tunes LS1s and have them tune it out for 50 bucks or whatever they'll charge you to do it. It shouldn't be much. All they do it hook the car up, find the table, tune out the torque management, and done.
If you don't plan to do your own tuning (I hear it's quite a learning experience anyway) then don't spend the money on HPTuners.
