FINALLY! bought my cam MTI x1. What else do i need?
just bought my MTI x1 cam. I have comp 918s already installed. i'm picking up chromoly pushrods 7.4's.... anything else i need? cam install kits? what do they include?
just looking to make sure i have everything to make this easy...
i have no a/c or emission to get in the way so install shouldn't be to bad.
thanks... it is a 99t/a with 70k on the clock. replacement timing chains are cheap enough.. will i need to replace the oil pump? can i just reuse my stocker? this is not my DD and might see 4k miles a year.
Well it is a crap shoot and with the amount of work involved and seing it comes off for cam install, Yeah, I would at least buy a GM replacement (ported not necessary)
can i use all the bolts? i have great oil pressure in all conditions... do i have to replace the oil pump? will i have to buy a new oil pump o ring once i take the old one off? is there a timing cover gasket that needs to be replaced or use gasket sealer....
thanks
just want to have everything here before i start taking things apart.
thanks
thanks
thanks
replaced) and timing chain, it’s going to come down to personal reference and mileage on the car. Knowing your cars has 70K or more, I would replace it in a heart beat. All the post I've read state that it's cheap insurance (under 200.00) to upgrade while you're in there. So me personally I say "yes". I just upgraded mine on my 2002 Camaro SS, but that just me. Did I need to, who's to say. Make sure you get
some lock tight and a torque wrench it's well worth the time. You may even want to upgrade your under drive pulley while it's off.
well i just placed a order from MTI....ls6 timing chain, crank bolt, front crank seal, water pump seal, oil pump o ring,chromoly pushrods.. looking for a ls6 oil pump
Looks like a good list to me.
Now you need to add a LS6 intake too.
er...i thought i had one all lined up... but the guy seemed realllllllly shady... so i didn't pay him for fear of loosing 300+ dollars... this cam set up is costing some $... its not just buy a cam and put it in.. ha. already spent like 250 for cam (great deal), 120 pushrods, 45 timing chain, 60 for gaskets, thats it so far..... looking at like 100 for oil pump and 50 for oil pressure gauge. so you are looking at like 700 after its all done..
here is everything you will need:
new crank bolt
Valve Springs
New Retainers
New Valve locks
New Valve Seals
New Pushrods
New Oil Pump
LS2 Timing Chain
Timing Cover gasket
Crank seal
water pump seal
oil pump o-ring
LS1 Valve Spring Tool
Cam Install dowels
Dyno Tune
with the cost of doing everything right I would budget around $1500 when its all said and done.......
new crank bolt
Valve Springs
New Retainers
New Valve locks
New Valve Seals
New Pushrods
New Oil Pump
LS2 Timing Chain
Timing Cover gasket
Crank seal
water pump seal
oil pump o-ring
Cam Install dowels
Dyno Tune
Whatever you do, do it right because it cost even more to do it a second time because something goes wrong. I'm super cheap myself, but I plan to do all the extras. Sounds like you'll be fine. If you aren't able to do it youself, go to a reputable shop because those shadetree guys don't usually stand behind their work.
my good friend has done many many cam swaps. i built a ton of cars overs the years and done other work for me. he's already looked at everything and has all the tools to make this go smoothly.
