Lets play spot the issue! HPTuners log and config inside.
Car leans out at 3600 can anyone here spot whats going on or have any suggestions?
www.andrew-wong.com/tune/7-18-07-4.hpl
www.andrew-wong.com/tune/7-18-07-5.hpt
Senior Member
Youre VE is fucked! Your MAF curve is untuned.. Timing table is fucked... Have you ever tuned a car before?
Youre commanding 9-11*s of timing at WOT at 5600+. It should be ~29. You have negitive timing at WOT in your low octain tables....
Senior Member
Originally Posted by Frost
Holy &*#)!!!
MAKE him put the stock file back on and DO NOT let him "tune" on your car further. I'm serious, I've never seen anything like this.
On first glance I thought this must be a joke...
Wow... that is one messed up tune... 2002 Escalade.. hmmm. I'm going to find a stock tune for one to compare.
.... OK I found a stock tune to compare and the spark tables on the tune are STOCK!! They run negative timing stock like that. Looks like not much was changed form the stock tune that VE table is scary though. That needs to be set back to stock and the Widebands need to be looked at because they read completely different from eachother.
