Western Members CA, AZ, NV, UT, CO, NM, HI
Any good shop that will fix my rear main seal?
Old 07-18-2007, 06:10 PM
rican_boi310's Avatar
Default Any good shop that will fix my rear main seal?
So far I have went to one shop and they qouted me $400 to change my rear main seal and change the oil pan. My car is leaking enough oil to the point where I should get this fixed.My Buudy that works at Midas looked at the car and he said I dont have to rush to get this fixed as long as I make sure there is enough oil and he said jus dont be driving crazy and racing, so I calmed down on that. The car has been like this for about 3 months. I just haven't had the money and now I do. I always check my oil and get the oil changed. The low oil light comes on way before I have to get an oil change, but I make sure I top the oil off with about 2 qts. So anyways im looking to get this fixed soon and wanna know where the good shops are. Basically anywhere in Los Angeles, Orange County, San Gabriel Vallley, Inland Empire, San Fernando Valley and so on is coo. So fellas I need your help once again. Any thoughts or input is appreciated.....THANKS
Old 07-19-2007, 04:18 PM
OneBadLT195Z28's Avatar
Thumbs up
I would recommend Don Lee Auto located in Rancho Cucamonga. They replaced my 1995 Camaro Z28's oil pan and knock on wood it has not leaked. Here is their contact info:
Don Lee Auto
9793 Foothill Blvd.
Cucamonga, CA 91730
(909) 989-1573
www.donleeauto.com
Call them and ask for Tim. Tell Tim Eric with the White 1995 Camaro Z28 sent you. If you have any questions please feel free to contact me. Thanks.
Old 07-19-2007, 09:30 PM
Alright....I'm goiing to contact them...thanks man
Old 07-20-2007, 08:06 AM
StoreKeeper99Z28's Avatar
Thumbs up
Don Lee Auto
9793 Foothill Blvd.
Cucamonga, CA 91730
(909) 989-1573
www.donleeauto.com
+1
Rx Bruce/StoreKeeper
Old 07-20-2007, 11:19 AM
travie319's Avatar
call CMS...........
Old 07-20-2007, 11:35 AM
LS1TECH Sponsor
ALLBOTTLE's Avatar
Give us a call at the Shop
951-471-2898
If you plan on swapping out your converter this would be a good time to do it, it would save you form having to pay for labor again since the converter and flex plate have to be removed to access the rear main seal.
Old 07-20-2007, 03:20 PM
Almostryan3's Avatar
SP motorsports....
http://www.spmotorsports.net/
Old 07-20-2007, 06:16 PM
Ok....sounds good...I will be contacting all those shops...you guys are always helpful!THANKS
Old 07-20-2007, 06:20 PM
no problem
Old 07-21-2007, 02:32 PM
joelx21's Avatar
My car is also leaking oil and I have a suspicion that it might also be the rear main seal Well, like it was said, it's a good excuse to throw in a new torque converter.....
Old 07-22-2007, 02:03 AM
How much would a decent torque converter cost. The reason I ask is because I don't have money like that right now but if its not that much then I guess it would be a good idea to swap the converter. Then again my car is bone stock and is it worth it to swap the converter for my first mod, and I have about 112k on the engine. I don't know what should I do! Let me know guys!
Old 07-22-2007, 03:46 AM
joelx21's Avatar
I heard fuddle is a great company. You're looking at around $450 bucks
Old 07-22-2007, 05:30 AM
GTObsessor's Avatar
+1 for Don Lee.
Old 07-22-2007, 12:02 PM
ZexGX's Avatar
I'm in the same position... You guys wouldn't mind working on a 3.8 A4 would ya?
Quick Reply: Any good shop that will fix my rear main seal?
