Automatic Transmission - Torque specs for trans mount please
cpd004
07-18-2007, 08:37 PM
Does anyone have this info handy? Thanks.
Hooper
07-18-2007, 08:53 PM
I think it's 18ft/lbs.
cpd004
07-18-2007, 09:56 PM
Thanks, but is that for the nut goung through the crossmember or the mount to trans? I need all the specs including crossmember please.
Vince @ FLT
07-18-2007, 10:30 PM
18ftlbs....http://wiki.ls1tech.com/index.php?title=Torque_specs
cals400ex
07-19-2007, 01:45 AM
it is 18 for the mount to the tranny. i am not sure about the ones from the mount to the cross member or the ones from the crossmember to the frame.
cpd004
07-19-2007, 07:25 AM
I saw the 18 for the mount to the trans. The nut on the bottom (mount to crossmember) and the crossmember (to frame) are not listed. They are for the t56 in the link you provided.
Vince @ FLT
07-19-2007, 07:31 AM
I see that they are only giving the spec's for the cross member and the mount nut for the t56. However the mounts and the cross members are basically the same and I think that you will be just fine using those spec's. I will have to look at the service manual when I get to the shop today and verify this for you. Vince
cpd004
07-19-2007, 11:32 AM
Thank you!! I was going to use those as well because I figured the same as you...it can't be much different.
kaos_
07-19-2007, 12:54 PM
if you tighten the bolt past 18 ft/lb torque will that cause a lot of vibration from that area since there is more pressure? when mine was put on it was just tightened really well. we didn't go by torque specs.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
