Torque arm and TSP TDs?
Old 07-19-2007, 03:12 AM
sidewayz28's Avatar
Default Torque arm and TSP TDs?
which torque arm will clear TSP true duals? i tried a searching but nothing would ever come up.. another question.. say i get a torque arm and im still on the 10 bolt, if that ends up breaking, and i switch to lets say a 12 bolt, i shouldnt have any problems bolting it back up correct? i was hoping one of the UMI T/A would be the one
Old 07-19-2007, 07:21 AM
86formula's Avatar
hopefully UMI performance will chime in with part numbers but i already contacted them about it. i believe any trans mounted TA will clear fine and if your looking for a chassis mount then you have to get a trans mount with a relocation kit/ it a litle more money but itll get you what your looking for.
Old 07-19-2007, 07:38 AM
UMI Performance's Avatar
Hello,
Our item # 2205 that is shown in the link below was actually designed around the the TSP true dual system. It will clear fine and will actually add addtional clearance to allow you to tuck the system up a little bit higher. Please take a look at the installation picture below as well as the installation pictures in the link. Also this item will bolt up to the 10-Bolt, 12-Bolt and 9" rear ends.
www.umiperformance.com/2205
Old 07-19-2007, 03:41 PM
sidewayz28's Avatar
THIS is why every suspension part of my car is UMI thank you!
Old 07-19-2007, 03:45 PM
sidewayz28's Avatar
so there really are traction improvements huh?
Old 07-20-2007, 11:57 PM
98mysticZ's Avatar
hey which frame mounted torque arm non tranny mount was done for the duals? and did it have a dsl?
Old 07-21-2007, 01:56 AM
sidewayz28's Avatar
yeah curious about this as well
Old 07-21-2007, 10:01 AM
The tunnel mounted torque arms are not going to clear the TSP system, that is why I have recommended the item above. If you want to run a tunnel mounted torque arm and true duals we recommend purchasing the torque arm and have a exhaust shop build the system around the torque arm.
Hope that helps,
Ryan
