knock sensor
Old 07-19-2007, 02:12 PM
ls1transam346's Avatar
Default knock sensor
i have my motor pulled to change a few things along with my knock sensors the one in the back was dry but there was oil around the front one. seemed like a small amount. is it ok or should it not have any oil around it?
Old 07-19-2007, 04:00 PM
figured out the problem of why the oil was is there
Old 07-19-2007, 06:27 PM
joecar's Avatar
Why was it...?
Old 07-19-2007, 08:05 PM
there are seals around the knock sensors that connect to that cap that houses the sensors in a sense. its hard to explain. when you remove the intake there is like a metal plate where the knock sensors go in.where the sensors screw in at the bottom was a seal. the seal was supposed to be connected to the cap but wasnt. therefore oil was getting into that area and around the knock sensor. i put the seals back in along with some black rtv.
Old 07-19-2007, 10:59 PM
Xtnct00WS6's Avatar
One of my knock sensors had oil on it too so I used to RTV sealant around the bottom. I'm not sure if I had to, but I changed the knock sensor that had oil on it.
