Paint & Body Work - Trans Am Front bird shave.
View Full Version : Trans Am Front bird shave.
Ws6Extreme
07-19-2007, 06:53 PM
Which compound to fill in (shave) the front bird on a Trans Am? I want to do this but forgot what the compound was called?
toplessHO
07-19-2007, 07:14 PM
Are you talking about the one on top of the bumper nose?
You can just peel it off.
Ws6Extreme
07-19-2007, 09:31 PM
No I am talking about filling in the gap around the Trans Am's front bumper license plate filler so it looks like the bumper is one larger piece.
fastvert
07-20-2007, 02:33 PM
http://ls1tech.com/forums/showthread.php?t=602023
fastvert
07-20-2007, 02:34 PM
"fiberglass will crack with a little bit of flex...they make a urethane based body filler which is what i used on my camaro for the holes in the bumper after i removed the grill." found via the search i listed above
jegan1989
07-21-2007, 07:58 PM
you can coat the inside of the filler whay it the opening is on the back with it in with bond do fill it in good then after everything drys shaved the bird off with a sander or sand paper done till it looks like you want it too
Ws6Extreme
07-21-2007, 08:36 PM
Whats that Urethane filler called? How hard was it to fill in those holes yourself? If I can I would rather DIY..... Thanks for the info.
jegan1989
07-21-2007, 08:40 PM
i would do one for you if you want my family owns a body shop so it would be no problem and then we could paint it for you if you want
