Torque specs for the crank pulley
Old 07-20-2007, 05:54 AM
blk05coupe's Avatar
Default Torque specs for the crank pulley
getting a little wobble and the AC belt has come off a couple times so its been suggested i check it, its an 05 LS2.
thanks
Old 07-20-2007, 06:39 AM
Street Legal's Avatar
Installation Pass to Ensure the Balancer is Completely Installed 330 Nm (240 ft. lbs.)
First Pass - Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes 50 Nm (37 ft. lbs.)
Final Pass 140 degrees
Old 07-22-2007, 05:02 AM
RGKSR's Avatar
Default I'd think about replacing the balancer.
I'd think about replacing the balancer and using the ARP bolt. Once they start to wobble it might cause the balancer to crank clearances to grow.
Bob K.
Quick Reply: Torque specs for the crank pulley
