need torque specs for clutch install
Old 07-20-2007, 09:48 PM
MadMike 97 Z28's Avatar
Default need torque specs for clutch install
so i am in the middle of a clutch install on my 97 LT1 M6 and tommorow the clutch should be going in i need the torque specs for all the usual (pressure plate to flywheel, flywheel to crank, bellhousing etc...) do you guys know where i can find these specs? i lost my printouts i had from alldata and shopkey.
Old 07-20-2007, 10:41 PM
PureWS6's Avatar
I also need these for my clutch install....putting a LS7 clutch/LS2 flywheel into a 01 T56
Old 07-21-2007, 03:59 AM
Mr.WS6's Avatar
check this web out it would help on the torque specs. http://www.installuniversity.com/ins...sity/index.htm
Old 07-21-2007, 11:31 AM
would the torque specs be the same for a pull type LT1 T56 as a push type LS1 T56?
Old 07-21-2007, 06:54 PM
brad8266's Avatar
the ls1 is 75 on the flywheel and 55 on the PP bolts. I would imagine the LT1 would be close.
Quick Reply: need torque specs for clutch install
