alignment problems...
Old 07-21-2007, 10:57 AM
joeboulley's Avatar
Default alignment problems...
hey what's up everyone.
i have an alignment problem. the front lower a arm(s) are slipping inside the slot joint. i brought this car to a GM dealership to be aligned a couple years ago. then i brought the car to a different shop and they said the cam locks are missing, and that is why the front is slipping out of alignment. i first noticed the problem while accidently sliding from gravel to pavement at about 20 mph. upon contacting the pavement the car jerked and i heard a loud pop. the weld that was applied at the dealership broke and my outside washer that was cut by the dealership isn't holding correctly. what should i do?
also, the BMR front lower arms are bending on the plate where the shock meets the lower arm. is this normal?
parts on my car.
FRONT
BMR upper and lower control arms
REAR
BMR LCA
Panhard
lower control arm relocation brackets
all four eibach pro springs and bilstien shocks
