General Maintenance & Repairs - seafoaming question
View Full Version : seafoaming question
fuseone
07-21-2007, 03:29 PM
yea i went to seafoam my 01 t/a and when i pulled the brake booster vaccum hose it didnt rev up to like 2000 or 3000 rpm like it said in the write up it actully was idealing low and was seeming like it was about to stall out my engine so i stopped right there and didnt do it why is that it didnt rev up high like that?
fuseone
07-21-2007, 04:07 PM
any one know why? could it be that my a/f is out of wack and i need to have it tuned first
fuseone
07-21-2007, 05:24 PM
any one going to reply? i really would like to know whats up with it.
Dan
07-21-2007, 05:35 PM
it's fine..I think I remember mine shot up & then sounded like it wanted to stall without the hose on
fuseone
07-21-2007, 05:40 PM
well when i pulled it off it shot up to like say 1500 then quick dropped to 500 rpm i would say so i didnt evne pour any in so you are saying thats normal?
Formula413
07-21-2007, 05:58 PM
When I did mine any time I would try to disconnect the booster line the engine would die instantly. I had to use a pair of vise grips (with some cardboard to protect the rubber hose) to hold it almost completely shut so the engine wouldn't stall, the small opening was still enough to feed the Seafoam in. Hope this helps.
fuseone
07-21-2007, 07:04 PM
it does help when i read the sticky it said the ideal should be at like 2000 or 3000 so thats why i got worryed about it. and just to make sure you are supose to use half of a sea foam bottle or just quater of it?
SchultzLT1
07-21-2007, 07:17 PM
i think its a third
sdm1234
just regulate it from stalling with the tip of your thumb. you're fine to pour some in.
Blazingz28
07-22-2007, 01:59 PM
I have the car off, and pull off the booster, hold the cup of seafoam underneath, turn on the engine, it sucks it all up and kills it. Replace the booster, wait 5 mins.. start it up (might need a lil gassing) and enjoy the smoke
purple98haz28
07-22-2007, 04:39 PM
so does this really make a difference to power and mpg. i know it depends on the car but i am thinking of doing it to my 125k ls1. any drawbacks
CodeName Z06
07-23-2007, 11:24 AM
I am also interested to see if their are any drawbacks to using it high mileage cars. I want to use it on my dads work truck with about 130k, will the removeing of the carbon build up on the vales and such cause problems, since the valves have been sealing on the carbon etc..
Any commnet would be great since i really want to do it just sacred of the consequences. Thanks.
Havok2
07-23-2007, 01:12 PM
yup, wouldnt use it on older cars for the reason you posted
1QuikZ
07-23-2007, 01:26 PM
yeah, typically a huge vacuum leak will make the car die. just put ur finger over the hose while its disconnected from the booster and pull ur finger away to suck in the seafoam.
CodeName Z06
07-23-2007, 08:08 PM
Anyone have any experince on high mileage 120k+ and seafoam?
purple98haz28
07-26-2007, 09:56 PM
ttt can i use at 120k +
Formula413
07-26-2007, 10:09 PM
Sounds like some people think it is iffy at high miles because of the possibility of dislodging enough junk to cause problems. I don't think anyone could tell you for sure one way or the other, I would just use your best judgement. Personally, I think the benifits outweigh the potential problems, but it's your car. Make sure you have read and understand the writeup on how to use it first.
