Forced Induction - My S80 DIY kit is finally done.
datsbad
07-21-2007, 10:21 PM
Thanks to the guys at Forced Inductions I got my 98 Z finally finished up .
This was my first Turbo build and Jose was very helpful .
Stock short block , ARP bolts
DART225'S done by Bret Bauer
Bret Bauer Comp cam
FAST 90/90
60LBS Injectors
TH400 RMVB WITH BRAKE
9", 3:50 gear
Blah, blah , blah
Here are a few pics. No numbers yet , I wont be dynoing it , just a SD street tune.
I am making 12 psi and it hauls ass , cant wait till its totally tuned and I get the transbrake working.
2 weeks I should have some numbers.
My goal is 9.80's on drag radials. Should be doable , then a LSX block will find a new home between the strut towers.
Some things are not permanant, I will be cleaning up and doing some powdercoating and -4 line connections everywhere.
http://www.gforcedesignconcepts.com/albums/98camaro/IMG_2653.jpg
http://www.gforcedesignconcepts.com/albums/98camaro/IMG_2681.jpg
http://www.gforcedesignconcepts.com/albums/98camaro/IMG_2680.jpg
http://www.gforcedesignconcepts.com/albums/98camaro/IMG_2671.jpg
Phil99vette
07-21-2007, 10:26 PM
Looks pretty good. I don't like how the wastegate tube runs backwards against the header tubes but if it controls boost than Sh*t on it. Post a clip of how that bad boy runs! When you hittin the track?
Phil
datsbad
07-21-2007, 10:29 PM
Phil
Next time I will make it a little different I agree, But it does work , so Sh*t on it like you say .
Track in 2 weeks maybe. I dont think the 60's will be big enough but we will see.
Phil99vette
07-21-2007, 10:31 PM
Good luck man, loved to see you get some high 130s or 140s out of that thing. What is your ET goal?
Beaflag VonRathburg
07-22-2007, 12:41 AM
That's one hell of an exhaust! Or is it lack of exhaust?
Josh@KY-Turbo
07-22-2007, 07:51 AM
It has a big S80 turbo muffler.... :devil:
Should be bad ass.
unit213
07-22-2007, 08:56 AM
That car looks like it's all business! :thumb:
datsbad
07-22-2007, 09:25 AM
It is open 4" downpipe now , I plan to maybe change it later down to 3" and run a muffler of some sort.
It isnt that bad driving now but with the pedal to the wood it screams.
ET goal right now is high 9 something, just to prove a point to some locals. I plan to put a LSX block in it and appropriate heads.
We will be starting the chromoly cage in a few weeks, and do some lighting of the car .
I plan to remove the ac box and the factory dash assembly and go to BS3 with a Racepak gauge set up .
NA$TY-TA
07-22-2007, 11:23 AM
Sweet... Im glad your planning another short block..... i saw you say 12 psi on a stock bottom-end and my 1st thought was damn.... lets see how long thats lasts...
Post up when ya hit the track man.
Kyle
99Z28LS1
07-22-2007, 01:46 PM
this is such a nice car no doubt. you should have no problem with your ET goal
datsbad
07-22-2007, 08:51 PM
Kyle
12 psi yeah , I know I am worrying about that also . I may try to lower that some.
thursday I will have some C16 in it and do some tunning, I hope it will stay together.
What is the max boost you have seen on a stock short block ?
I have always loved you car Kyle. Mine is some what on a budget, LOL !!
LS1 and Turbo on a budget .....is there such a thing???? LOL !
datsbad
07-22-2007, 08:55 PM
LACK OF BROTHER !. IT SOUNDS BADASS
I might change it .
I have already had the cops to my business, I know a few local officers and they tell me they were warned to keep an eye out for this car . LIKE they dont have anything better to do , LOL !!!
There is some build pics on my site under Gallery on the 2nd page.
NA$TY-TA
07-23-2007, 09:51 AM
The C16 should help some..... just be safe and try not to run alot of timing with it....
Yeah there is no such thing as Budget...
Thanks for the compliments about the car....
If ya liked it before.... just wait about 2 more months....
New Motor, Bigger Turbo, and a few lil things :devil:
Keep us updated.
Kyle
01ramair500hp
07-23-2007, 06:46 PM
how far did you have to move the radiator foreward to get that to fit ???
datsbad
07-23-2007, 09:39 PM
Keep us updated.
Kyle
WELL TODAY WAS NOT GOOD....I went for a little ride and had some unexpected red windshield washer fluid appear on the windshiled at about 130 mph ......looks like its coming apart tomorrow.
LSX might be sooner than later, LOL !!
blacktransam
07-23-2007, 09:47 PM
sure you didn;t blow the trans dip stick out??
datsbad
07-23-2007, 09:49 PM
AHHH, NO !
Dex Cool everywhere!
Josh@KY-Turbo
07-23-2007, 10:15 PM
Bigger is better anyway.
datsbad
07-25-2007, 09:59 PM
Well found the problem , Damn gaskets I was told to use are junk .
Heads are at the machine shop , block is fine, new gaskets from cometic on monday , Hopefully it will be running again soon.
Beaflag VonRathburg
07-26-2007, 09:10 PM
That would suck to only have it done for a short time and then blamo.
datsbad
07-26-2007, 09:38 PM
Yeah damn transbrake selenoid wont work either, Might as well get that fixed while its down .
98camaroLS1M6
07-26-2007, 09:52 PM
nice setup! :)
HUNTER02SS
07-26-2007, 09:53 PM
I see you are using dart head's also. I have a set a deciding on whether or not to oring them or just sell them and get something with a thicker deck. I already have them though so I will probably oring them and see what happen's. :drive:
Q8CamaRo
nice setup.. keep it up
DrTurbo
07-27-2007, 11:03 AM
Looks like that S80 will make some stupid power on that car. Should be a solid 8 sec car.
Whistler
07-27-2007, 03:39 PM
What gaskets were you running?
