88mm turbo
Old 07-23-2007, 03:53 AM
dmracing's Avatar
Default 88mm turbo
How much power will one make?
Old 07-23-2007, 04:04 AM
LebaneseShowoff's Avatar
1100HP+ Depending on the set up.
Old 07-23-2007, 04:11 AM
navymitch12's Avatar
the turbo by its self.....
a solid 2hp.....maybe if your lucky and going downhill
if you were to add a motor and some other things prob a lot more!
sorry had to be a smart ***
Old 07-23-2007, 08:02 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
MY GT47-88 will reportedly make over 1200hp, maybe it was 1400. I'm probably at 1000-1050 at the crank right now.
Old 07-23-2007, 08:13 AM
Mr.MartyStone's Avatar
a real 88 should be able to max out at 1500hp. It's probably an honest 1150 wheel hp turbo in a 6.6L application.
Marty
Old 07-23-2007, 08:18 AM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
Depending on which 88mm unit you are talking about, they will range from about 950-1200rwhp depending on the efficiency. The cubic inches will play the biggest factor.
Old 07-24-2007, 02:36 AM
Exactly what I was saying.
Marty
