L92's on a Big Bore 388
Old 07-23-2007, 11:48 AM
355ss's Avatar
Default L92's on a Big Bore 388
I have a Ls2 that has needs one of the sleeves replaced. I am thinking about sending out and having all new sleeves installed and going with a 4.125 bore and stock stroke. Has any one else done this? I think that the larger bore and more cubic inches are going to make the L92 heads work better than being on a 6.0???
Old 07-23-2007, 12:12 PM
blu00rdstr's Avatar
I'm also considering L92s instead of Stage 2 CNC'd LS1 heads on my 4.125" block. I'm unsure if stock L92s will perform that much differently than ported LS1 heads.
Old 07-23-2007, 01:27 PM
Mikey 97Z M6's Avatar
My 387 all-bore engine will be getting L92's. The guy that owned this 387 shortblock before me had some heavily ported TEA LS1 style heads that put down 473rwhp on a mustang dyno. Should be real interesting to see how the L92's do in comparison.
You planning to go with dry sleeves or wet?
Mike
Old 07-23-2007, 02:59 PM
355ss's Avatar
I haven't looked to much into the differences in dry or wet sleeves so I am going to start researching it tonight. I have read that the darton sleeves are the way to go.
Old 07-23-2007, 10:51 PM
NemesisC5's Avatar
Should make for a great rpm motor and VERY responsive ! !
Old 07-24-2007, 10:54 AM
93TAWicked1's Avatar
I'm the one who sold the 388 or 387 or whatever it was, I liked it, I had 317's that flowed similar to ported L92's except better on the exaust side and smaller runner. I made that 473 with a smaller cam and an LS6 90mm intake setup. The car moved and loved to rev, the only thing is if you are going to buy a 2600 block and 550 pistons, 500 rods, whats another 1000 for a 4 inch crank? Of course that kind of thinking is what got me into my current predicament.......
Old 07-24-2007, 11:28 AM
Sharpe's Avatar
Wouldn't it be more to sleeve a block than to just buy an L92 block and bore it? Maybe not. I wouldn't know.
Old 07-24-2007, 12:04 PM
blown4.6's Avatar
I bet you will be able to rev that thing to the moon, with proper valvetrain of course.
Old 07-24-2007, 12:33 PM
NemesisC5's Avatar
Any valvetrain recomendations ?
Old 07-27-2007, 09:47 AM
racecar's Avatar
Short stroke big bore motors rev quick and make big power in a narrow peak range.
That would be an awesome motor with great top end power, it will have low end power, but it won't have the killer low end torque of a 4" crank.
Old 07-28-2007, 08:49 PM
Greg Fell's Avatar
Steve @ R.E.D. does not like the L92 block for resleeving.
Old 07-28-2007, 09:05 PM
blu00rdstr's Avatar
I had an email conversation with Steve @ R.E.D., great guy!
Dry sleeves on an LS2 are much less expensive than wet sleeves on an LS1, and LS6 blocks are not recommended for a resleeve.
R.E.D. provides LS2 dry sleeves in 4.125-4.190", but not bigger than 4.150" for FI or nitrous. I've seen Darton M.I.D. sleeves on ebay selling for $1,400, but for $260 more you could have your LS2 sleeved which includes stress relief work.
Old 07-28-2007, 10:25 PM
NemesisC5's Avatar
So how much $$$ for a dry sleeved 4.125" LS2 ???...Or is it less expensive than buying the LS7 block ?
Old 07-29-2007, 12:09 AM
blu00rdstr's Avatar
I found an LS7 block for $2,366 from gmpartsdirect (list price is $3,250). I'm unsure if an LS7 can be resleeved or bored much. I'm unsure, but I think a dry oil sump system is needed.
If you have an LS2 block, R.E.D. will stress relief the block, install sleeves, and deck the block for $1,670 (top secret info I got from Steve). $120 for stress relief, $800 for sleeves with installation of $750. Sleeves can be replaced in a sleeved block, and bore can go to 4.190".
Old 07-29-2007, 03:49 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
yeah my l92 block was the first l92 block he resleeved, he got it done perfectly, but he said the sleeves were in the block crooked, especially number 7 cylinder i believe.
Old 07-29-2007, 10:46 AM
355ss's Avatar
Does anyone have any insight on how the l92 heads perform on a 4.125" bore vs the smaller 4.00"
Old 07-29-2007, 11:14 AM
NemesisC5's Avatar
I've heard this MANY times, is the quality starting to improve?..If not it seems like LS2 or LS7 are the way to go
Quick Reply: L92's on a Big Bore 388
