Help, tranny " CLUNK"
Old 07-23-2007, 02:31 PM
stepuptata's Avatar
Default Help, tranny " CLUNK"
My 02 ws6 "clunks" .WHile setting in neutral, I press the clutch, place in first gear and it "clunks." With the clutch still depressed and not moving. It does this every now and then. If speed shifting, it "clunks"while shift into the next gear. It sounds like a bad mount, but I too kit out and its fine. Its the original, it has 25K on it. BTW, my car is a 383 stroker and makes 492 rwhp. It also has a n aftermarket torque arm, I check those bolts and everthing looked good. Thanks for any help or suggestions.
Old 07-23-2007, 07:37 PM
JonB's Avatar
If its not a shot tranny mount I would then look at your torque arm mount.
Old 07-23-2007, 09:44 PM
stepuptata's Avatar
Thanks for the peply. Its diffenetly not the torqe arm mount. I have inspected it and its solid and tight. Thanks.
Old 07-24-2007, 01:41 AM
JonB's Avatar
How are your motor mounts? What about exhaust pipes moving and hitting the floor pan?
Old 07-24-2007, 03:30 PM
stepuptata's Avatar
Exhaust is good. Plenty of distance. The motor mounts look good. I have not really looked that hard.@ idle, the engine dances back and forth and the exhaust tips shake side to side. But I figure that normal with a larger cam. WHat do yuo think? Thanks for the help.
Old 07-24-2007, 03:59 PM
11Second Club
Gauge's Avatar
Wait 'til the car is cold and try grabbing the exhaust and pulling it up and down. If it's not real stout, then you might want to look into new motor mounts.
Old 07-24-2007, 04:13 PM
stepuptata's Avatar
you mean, grad by the header pipe down by the collector? Correct? Thanks, I'll try that. It still has the factory OEM mounts and the car makes 492 rwhp. Any idea on what mounts to try? Thanks.
