View Poll Results: True duals or catback
True duals
137
77.84%
Catback
39
22.16%
Voters: 176. You may not vote on this poll
True duals or catback?????
ok so crunch time.... I just got my money back from the headers i never got 4 mouths ago and im reordering them...
So what is better True duals, or cat back?
Ive decided that the setup i wanted to go with, im just not gonna fit the way i want it to. So it would be true duals dumped with flanges so i can make them side exit so i can pass inspection, or gmmg or borla catback. both cost about the same when all said and done.
What do you think is better for a car thats not ever going to be lowered, that will proably be a cam only or maybe a head cam combo soon?
this is with pacesetter longtubes
IS there any power to be had over TD's? they sound freakin mean is the reason i want them and weveryone seems to dyno about the same either way. enless im just wrong?
This is taken from the true dual sticky at the top of the page:
Q. What kind of gains can I expect with true duals?
A. If you have stock exhaust you will pick up around 30HP by going to duals with a set of headers. If you already have headers and a cat-back, don’t expect a big gain, but some are to be had if the catback is very.
Q. What are the benefits of duals?
A. Many people believe that duals sound much better than cat-backs. I personally believe that a good dual setup sounds better than any cat-back I have heard. That is the main benefit of duals since they yield similar power gains with y-pipes and duals take bit more work to get to fit.
I've had both, so here's my input. I had a Borla adjustable catback on my car with Pacesetter longtubes and a TSP off road y. Sounded like absolute **** with the plate open, but pretty nice with the closed plate, almost no rasp. I decided to do my current dumped X pipe setup with Magnaflow 4x9s to try out duals. I will probably never go back to a catback now. The sound puts any catback with LT/ORY combo to shame. Now, you say you can't have it dumped due to inspection. Get yourself some S bends, and route it out the back under the axle, or whatever you want.
So will true duals work with my 1" lowered T/A?
What about true duals dumped vs true dual x-pipe out the back both over passenger side or over both sides or under both sides of rear end?
Originally Posted by CaMaRo67RS355
dumps can be found around $400-$500 bucks i went with the tsp rumbler x kit from texas speed. true duals are expensive as hell that ive seen if you go over the axle and out the back. yes true duals will work if your lowered there will be less ground clearance (duh) but if the true duals are installed carefully u can make them tuck very nicely under the car to get maximum ground clearance. ive seen a ws-6 with dumps that was lowered 1 1/2 inches and had almost 4 inches of groud clearance.
Yeah I was looking at that kit and if I sell my loud mouth and my y-pipe it should pay for most of the TD setup for me. You're right about how expensive it is to TD it out the back over the axle. Some kits go for $1100.00 or you have to buy the $200.00+ X piece then have someone custom build exhaust for you from headers to X piece then from X piece out the back. I was curious of how dirty it makes the car from having the tips dump to the ground and rumbly and what kind of interior vibration or tone defining you get from TDs. I guess you can turn the tips outward a little and allow for a little more clearance as well. 4" clearance with 1.5" drop...wow that's good. Maybe I will look into the true duals then.
I do like it loud so that's one reason I would go with them.
I understand how you have them angled, that just might work.
Wow that low and still not really and scraping problems, there is hope for me yet.
I have only found Texas Speed to be the only one making or selling them. Who else does?
Originally Posted by 95 Z28
If you spend some time getting them tucked up real nice you won't run into too many problems. I'm lowered (Pro-kit) and don't scrape very much, and my mufflers are somewhat large. And I can vouch for TSP, excellent product and from past experience with them, I can say their customer service is awesome. The only reason I chose not to run their kit is because I didn't like any of their available muffler choices.
How so? Is there another place with better muffler choices?
