LS6 Tabs
LS6 Tabs
Hey everyone. I just bought an LS6 intake and I want to keep the stock cooling tubes on my engine. What I wanted to know was if anyone had a picture or could show me the pattern of tabs that you need to grind off on the bottom of the intake to clear the cooling tubes. Thanks a lot.
ive seen this question asked before and never seen a pic of what you are looking for, plus i think it would be hard to get it right even if you did have a pic
its gonna probably take a couple of different tries for you to get all the correct ones ground off. my suggestion is to take your manifold off, put some light grease or assemble lube or something on the coolant pipes and then lightly set the manifold back on then lift it off & see where the pipes run. yeah its redneck but it worked for me
Found it. The guy who posted the pics posted in another thread. Heres the link for anyone else that needs it.
https://ls1tech.com/forums/generation-iii-external-engine/618070-finally-did-ls6-intake-swap.html
