Can't get the tranny lined up!
Old 07-24-2007, 02:43 PM
renxwar's Avatar
Default Can't get the tranny lined up!
I just spent 3 hours wiggling and moving. I finally got the input shaft in, now it seems like I'm having trouble getting those two little tabs on either side to slide in.. Does anyone have any tips? I'm about to pull my hair out..
Old 07-24-2007, 03:08 PM
brad8266's Avatar
Pain in the ***, just keep fighting it. Its way easier if you have a tranny jack or 2 people lifting.
Old 07-25-2007, 09:05 PM
GreaseMonkey83's Avatar
how did you align the clutch to the pilot bearing? you may have it in the clutch but you have to get the nose of the output shaft into the pilot bearing. If its off alittle, it will be a pain in the *** to get in and might have to be re-aligned.
Old 07-25-2007, 09:56 PM
Hobb3s's Avatar
I had the same problem and here's what I did. I went to a hardware store and found 4 bolts of the same size and length. I cut the heads of the bolts off and ground then them down to a round point and partially screwed them into the bellhousing (two on top & two on bottom). I then slid the transmission over the bolts and everything lined up great from then on.
Old 07-26-2007, 07:18 AM
renxwar's Avatar
I managed to get it on.. I feel like I got my *** kicked today cuz my arms are so sore, though. HOURS of wiggling.
Old 07-26-2007, 08:33 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Most likely the dowel pin holes were boogered up. I had that issue on a 02 z28 when we installed a transmission.
