Moore Performance valve spring tool!Anyone use it?
Old 05-17-2003, 12:37 PM
StreetStalkerZ's Avatar
Default Moore Performance valve spring tool!Anyone use it?
I'm going to order a valve spring tool soon to swap out the old 918 springs for some new 918s and came across the Moore Performance tool and wanted to know if it is any better than the standard clamp spring compressor? It looks nice to me and looks like it would be alot easier but i have not tried one and did not want to order it and find out that it was not what i exspected? Let me know what you think!
Old 05-17-2003, 12:49 PM
MOBE's Avatar
Default Re: Moore Performance valve spring tool!Anyone use it?
There was quite a bit of debate about this very suject about 10 days ago. It got mixed reviews.
Do a search!
Old 05-17-2003, 02:11 PM
BIG PD's Avatar
its good, but does the same thing as a 15 dollar valve spring tool just depends how lazy you are i guess.
Old 05-17-2003, 05:29 PM
Scalpel's Avatar
My experience was horrible with it. It was made of a **** poor tooling aluminum and didn't work as advertised. Search w/in the past two weeks on the internal section for the tool I use and it works the best of all. It only cost $15 too!
Old 05-17-2003, 07:32 PM
DONAIMIAN's Avatar
It would be so much better if it was made of tool steel or chromoly, or the craftsman tool stull (think its chromevanadium or something like that) But tools shouldnt be mader from aluminum regardless
Old 05-18-2003, 01:18 AM
Cal
Cal's Avatar
Yeah that's exactly what I was thinking . . . they had a great idea but used the wrong material. I'm actually thinking of making one like that myself out of steel. But in reality I think all you need to do is cut the end off a standard lever-action tool as mentioned above by cannibal. You just tighten down a bolt on it to compress the spring.
Old 05-18-2003, 01:45 AM
BSMDan's Avatar
We've been using at our shop for quite awhile now but only on changing from stock to the 918's. Not sure how it would work on the double spring or spring with a higher rate. So far we had no problems with it and it cut time by about half an hour or maybe more once we use it more often.
Dan
Old 05-18-2003, 11:38 AM
xaon's Avatar
I've used mine to remove a set of REV-1116 dual springs and then reinstall another set on the car. I will be using it again in a couple months to replace out another set of REV dual springs.
Old 05-18-2003, 02:43 PM
2000SILVERTA's Avatar
Scott, put in a BIG cam while your at it.
Old 05-18-2003, 02:51 PM
Stacy,that will be next year or later in the year If the money is right a set of TEA or Absolute heads will go on as well with a LS6 intake.
Old 05-18-2003, 08:47 PM
Savageite's Avatar
How many people have used that tool on installing the rev double springs on stock heads? I just ant to know if it works or not.
Old 05-18-2003, 09:11 PM
I can shift faster than you.
Jason99T/A's Avatar
The MORE tool works just fine on double springs!
Old 05-18-2003, 10:45 PM
Ramair346's Avatar
I've got a brand new More Performance tool that they sent me under warranty. I'll let it go for $110 shipped.
