IAT sensor and boost
Old 07-24-2007, 08:05 PM
Gold Phoenix's Avatar
Default IAT sensor and boost
First of all, the search engine sucks. I am not getting the results for the most easy topic and I am getting posts from years ago.
OK, I am concerned that the IAT sensor getting blown out with my F1R. I need to know if my concern is justified and some alternative designs.
Old 07-24-2007, 08:06 PM
T/A KID's Avatar
Get a Threaded IAT from FAST, and it uses a 3/8 bung. Problem solved.
Old 07-24-2007, 08:07 PM
JMBLOWNWS6's Avatar
Speed INC sells the setup you are looking for. Ive had cars up to 16 psi not push out the rubber one.
Old 07-24-2007, 08:11 PM
OK, where is it on their website? I guess I could take a stock one a epoxy it into the pipe.
Old 07-24-2007, 08:30 PM
Coal Mining Director
onfire's Avatar
I've used both. If the grommet is in properly it's not coming out under boost.
Old 07-24-2007, 08:32 PM
HUNTER02SS's Avatar
I agree. I have had no problem's either.
Old 07-24-2007, 08:35 PM
Is there any specific way that is best? What size hole should I drill in my pressure pipe?
Old 07-25-2007, 08:23 AM
Dumb Ass Vette Moderator
ls1290's Avatar
If the IAT sensor is placed in a metal pipe and the hole is sized correctly, it should stay in place even at 30 PSI. I have seen many IAT sensors come out that are mounted in the silicon couplers. It is bad to mount it there because the silicon is not ridged enough to hold is shape over 4 or 5 PSI. The silicon just flexes too much.
Keith
Old 07-25-2007, 10:02 AM
NoGo's Avatar
I just got rid of mine and put a resistor in the IAT. 3bar OL-SD tune here.
Old 07-25-2007, 10:10 AM
onfire's Avatar
3bar olsd here also. But I like to use mine to drop timing at he big end as the iat's come up.
Quick Reply: IAT sensor and boost
