first time at the track=12.88
I took my car to the track for the first time, I was expecting better times but I need to get my 60' time down first. I had et streets running at 18psi and the best 60' time was in the 1.9's.
I brake stalled the car right around 3000 rpms for this run which seemed to be a good spot, it pretty much dead hooked. The next run I tried brake stalling it to 3600 and it spun the first 60 foot, it was still a 12 second run and my highest trap speed of the night so maybe I needed to let a little more air out of the tires. What do I need to do to get a 1.7 60' time?
Anyway here is my best run last night
reaction time.........090
60".....................1.94
330....................5.437
1/8....................8.313
mph...................85.51
1000'.................10.791
1/4....................12.882
mph...................107.89
Maybe try to launch at a few different rpms. Some converters like to be stalled up, and sometimes you do better at a lower rpm and it flashes the converter harder. If you are dead hooking, try a lower footbrake rpm and see if the converter flashes higher and maybe it will 60ft a little better?
i would be happy if i got 12s. went to track sunday ran 2 xs. these are my times r/t 0.098 0.104
60' 1.871 1.868
330 5.437 5.456
1/8 8.388 8.410
mph 83.63 84.96
1000' 10.943 10.986
1/4 13.112 13.156
mph 103.74 105.18 i think mph is off on 2nd. run . all other runs i have, all are in 102.75-103.13 range. this mph has not changed even after i had madz 28 tune it. i only have street tires , but they hook well.
98z a4 3.23 relo brackets, mail tune , borla ,3200 yank stall. car has 93000 miles. dd.
60' 1.871 1.868
330 5.437 5.456
1/8 8.388 8.410
mph 83.63 84.96
1000' 10.943 10.986
1/4 13.112 13.156
