Broke ARP head stud on Smokinhawk's car -- Ideas?
Putting some new head gaskets in. Since he is running higher boost, I decided to go 80 pounds on the 3rd torque pass. First stud we hit snapped under the brutal torque of Jonathon's incredible strength
I was very surprised to say the least. Now gotta figure out how to get it out. Gonna try an 1/4-inch, 8mm socket as a guide in the hole. Then use a bit through the socket to drill into the stud hopefully. Then try the easy out. If I can't get it, I guess I will pull his motor and take it to the machine shop.
Anyone else broke an ARP stud? Will they replace it?
Re: Broke ARP head stud on Smokinhawk's car -- Ideas?
If you have a mig welder its very easy. Start welding on the center of the stud(weld a little ball let it cool for 30 sec weld a little more ect.)until its tall enough to grab with vise grips then turn it out with the vise grips. The weld will not stick to the aluminum.
That is a great idea, but the stud broke off about 3 inches down into the hole. The method I talked about worked OK. Got the pilot hole started with the socket in there. Then used a larger bit to bore down a bit. Then a long 3/16" bit to bore some more. Got the easy out in and it broke right loose.
I will remember that for next time though if the bolt breaks off closer to the surface.
