Factory oil pressure gauge acting all funny!!!
Old 07-25-2007, 01:48 PM
SIC LSX's Avatar
Default Factory oil pressure gauge acting all funny!!!
oil pressure is good it just bounces all over the place and gets stuck every now and then any ideas??
Old 07-25-2007, 02:36 PM
robertbartsch's Avatar
My oil pump went south (99 SS) a few years ago and the guage acted this way - so beware.
You can replace the sensor/presure sending unit, but I would watch this like a hawk.
You can take the oil filler cap off during idle to confirm oil is being pumped to the rockers, I suppose.
This would make me nervous. ...any metal shavings in the oil?
Old 07-25-2007, 02:53 PM
SIC LSX's Avatar
its not that its getting low never below 40psi in heat! its just if i get on it the pressure goes up like it should and when it should go down after i let of it sticks! Or if i rev it it goes all over the place like it gauge is bad or somthing
About to change oil now
Old 07-25-2007, 03:01 PM
Yeh, but mine did that too. One day, I started the engine and - no pressure!
Factory pumps from the early days were problematic.
Old 07-25-2007, 03:36 PM
SIC LSX's Avatar
**** i hope thats not it because I'm about to go on a Road trip from KC mo area to Home town Pensacola Florida will be putting about 2,000miles on car round trip! I hope thats not it! It has been doing it for about 2 months or more
Just changed oil not metal at on on drain plug
Old 07-25-2007, 03:56 PM
Changing the oil pump is a PITA.
Pull the raditor, hoses, belts, and crank pulley bolt and crank pulley. Pull the timing cover, timing chain, loosen the oil pan, and finally get the pump and disconnect pickup tube. Replace the pump and use a new oil pickup tube O-ring and a new TTY crank bolt. Replace all the junk you just removed in reverse order.
Uhg! I don't ever want to change that *&^% again!
Old 07-25-2007, 04:01 PM
SIC LSX's Avatar
yeah i know what to do i just dont want to do it LOL I have been also hearing about the factory gauge clusters going bad! Ill hook up a aftermarket gauge b4 i do all that LOL
Old 07-25-2007, 04:06 PM
GM had many failures on 98/99 LS1 cars. To me, it is amazing that they avoided a manditory recall for faulty oil pumps.
I called the dealer who told me to run the engine with no presure since GM would likely buy me a new engine! Right!
Old 07-25-2007, 04:17 PM
I can't remember why these pumps went bad but the pump gears were not the issue. I think it might have been faulty springs inside the pump that govern the pressure, however.
You could use an external pressure guage to confirm pressure but that will not give you any assurance that the spring in the pump might malfunction at any time in the future and shut off oil completely.
I think the pressure unit (brass) is on the driver's head near the 1st plug.
Old 07-25-2007, 04:19 PM
SIC LSX's Avatar
im thinking a easy way to tell if its the gauge is to pull my gauge cluster out put someone elses in and see if it still dose it????
Old 07-25-2007, 04:35 PM
SIC LSX's Avatar
also just had someone pm me this
Hey, I have the same problem as you. I have a 99 T/A and my gauge does the exact same thing. I seriously doubt it's your oil pump because mine was doing it before I swapped a cam in(new ported ls6 pump) and is still doing the same thing. Most likely it's your oil pressure sending unit. Let me know how things work out for you.
Old 07-25-2007, 04:59 PM
SIC LSX's Avatar
Well did the oil change and went from M1 0w-40 to M1 5w-30 man the oil pressure is up more! was around 70psi for a while then dove it around in 95 deg heat and never got below 45 psi1 but still bounces around like it sticking when i let off!
One more question when i turn the car off the oil pressure gauge sticks at 40psi then you turn the key and it drops down to 0 then when it cranks it goes where it should! Is that noramal?
Old 07-25-2007, 05:02 PM
nassaublue's Avatar
hey man mine did that **** and a few months later i spun a rod bearing because the oil pump went out i had to get new rods new pistons and all that other good **** that goes in ther basically it fucked my motor so yeah if i was u i would have that oil pump changed i dont think it costs nearly as much as a new motor lol
Old 07-25-2007, 06:05 PM
SIC LSX's Avatar
ill check the gauge 1st! way cheeper and way easier
Old 07-26-2007, 09:25 PM
SIC LSX's Avatar
well i noticed something! Ok i turned my car off and back to the on position with the car not running with power to the gauges and it was still acting funny??
Old 07-26-2007, 10:49 PM
Soul TKR's Avatar
i don't really know much about this stuff... but I wonder if you were to disconnect the battery so that everything resets and then reconnect it if that would have any effect on it...?
Old 07-26-2007, 11:08 PM
transam5.7lt1's Avatar
Sounds like a faulty oil sending unit and not your gauges/cluster.
Old 07-26-2007, 11:15 PM
98Camarod's Avatar
Take the manifold off and replace the sending unit. I think it was like 35 bucks. I joined the broken oil sending unit club on my ls6 intake swap. The damn brake booster line got caught and broke it. On the bright side I added oil pressure by switching sendin units
Old 07-26-2007, 11:19 PM
Soul TKR's Avatar
is the sending unit the one on the back of the manifold everyone talks about breaking when they do an IM swap?
Old 07-26-2007, 11:21 PM
98Camarod's Avatar
Its not on the manifold, its behind it on the block.
Quick Reply: Factory oil pressure gauge acting all funny!!!
