Can somebody double-check me?
Old 07-25-2007, 05:11 PM
sixthfloorfreak's Avatar
Default Can somebody double-check me?
I'm pulling the motor out of my car to install cam, heads, HS roller rockers, oil pump, timing set, and rod bolts, as well as new headers and a FAST intake. I just need to make sure I have all the misc. hardware I need to go back together with it so I don't have to wait around on parts.
So far I have:
head bolts
oil pan gasket
timing cover gasket
water pump gaskets
front crankshaft seal
head gaskets
pipe/plugs for FAST intake install
What else am I missing? I'm very new to this, so pardon the newb question. I'm bound and determined to do this myself, but I've just never done much internal engine stuff before.
Old 07-25-2007, 05:15 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Crank bolt.
And a longer, same thread, bolt to seat it prior to torquing.
Old 07-25-2007, 05:20 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Oil pump o-ring if your new pump for whatever reason doesn't come with one!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 07-25-2007, 05:28 PM
thanks guys! TSP was supposed to send me a crank bolt but it was backordered and I forgot all about it. guess I need to holler back at them. anything else?
Old 07-25-2007, 05:33 PM
sroach20's Avatar
why not poly mounts? since your pulling the engine.
Old 07-25-2007, 05:35 PM
sroach20, care to post a link?
also, Matt @ SDPC, the o-ring you mentioned, is that the same one that is mentioned in the rod bolt write-up pertaining to the oil pick-up?
Old 07-25-2007, 05:38 PM
sroach20's Avatar
http://www.ws6project.com/user_stor/...06c0e4012d4e69
Old 07-25-2007, 06:11 PM
Not sure which link you speak of, but yes...I am sure it will be the same one. It is the only o-ring in the vacinity that needs replacing often!
__________________
Old 07-25-2007, 06:14 PM
Matt, I was referring to the rod bolt install sticky toward the top of this very forum (internal engine forum). thanks again!
Old 07-25-2007, 06:24 PM
Yes, same o-ring mentioned in post #5 there!
Sorry, I'm guilty of looking straight past the stickies anymore...there are just too many for me to pay attention to or read
__________________
Old 07-25-2007, 06:26 PM
thanks for taking the time to help!
Old 07-25-2007, 06:48 PM
shooter's Avatar
Originally Posted by orangeapeel
Crank bolt.
It's a M16 bolt the threads are 2.00 pitch and the lenght is 5 inches.
Old 07-26-2007, 08:32 AM
so that's the size I want in a longer bolt, or is that the size of the stock crank bolt?
Old 07-31-2007, 08:38 AM
shooter's Avatar
Nope that what you want to get the pulling on the stock bolt is the same just shorter (4 1/4 inches).
