Good cubic inch for Procharger...
Old 07-25-2007, 05:33 PM
LT1dude's Avatar
Default Good cubic inch for Procharger...
What would be a good cubic inch to go with when it comes down to a D1S-C ProCharger? I have a 97 LT1 and a D1S-C, and I was wondering what a good displacement would be.. Wanting to see 600 to the wheels, more if possible, with a good set of heads, cam, intake, fuel sys... I was thinking 370 c.i.?
Old 07-25-2007, 05:42 PM
lethal93ta's Avatar
370 ci? where you getting 370 from? that would take some major work to get sleeves in there to only get 370 out of it, 355 4.030 3.5 stroke and 383s 4.030 bore 3.75 stroke are popular you just have to decide how you want to build it, a stroker has a little more torque to them, a 355 will have a little more top end RPM horse power to them.
Old 07-25-2007, 08:29 PM
LT1dude's Avatar
So you have a 383 and a procharger, what were your ending numbers with that combination? And how many pounds of boost are you running?
Old 07-25-2007, 08:30 PM
LT1dude's Avatar
The 370 idea came from a friend that was going to go turbo before he ended up going all nitrous. Well he was going to go 370, and that was with a forced induction mod, and so I figured that a supercharger would be "almost" the same as a turbo setup, minus a few odds and ends.
Old 07-25-2007, 11:28 PM
E Wagz's Avatar
I have a 402 with D1SC at 13.5 psi; dynoed at 675 rwhp/635 rwtq with a 8.78:1 CR. Car is completely streetable and has all of the daily driving luxuries.
Old 07-26-2007, 02:39 AM
LT1dude's Avatar
Yeah, but I am also working with an LT1.. Nice numbers though..
Old 07-26-2007, 04:18 AM
lethal93ta's Avatar
you can build a 377 from a 400 block and destroke it, but with out doing major work and putting sleeves in a LT block your not getting 370.
Old 07-26-2007, 04:46 AM
EPP
EPP's Avatar
I would go with a 383, and you're going to need a great set of heads for your plan. Bob
Old 07-26-2007, 07:56 AM
CHRISPY's Avatar
Turbos are different in many respects as you need to size the compressor to the cubes (or vice versa) or you can run into backpressure issues. This isn't as critical with a supercharger as it is belt driven though you can certainly undersize a blower to the motor...
I would throw a 4 inch stroke crank in it and keep it at 383ci with the D1SC. Good set of heads and a decent cam and you'll hit 700 plus on 15#s boost easily.
Cheers,
Chris
Old 07-26-2007, 09:36 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I would go with a 4.0" stroke crank to make a 383. The longer stroke crank will create good torque in the lower RPM range when the SC has not yet reached into its power band( upper RPMs ).
Keith
Old 07-26-2007, 03:58 PM
LT1dude's Avatar
Awesome guys! Thank, that would be great if I could hit 700 with that combo..
Old 07-26-2007, 04:05 PM
LT1dude's Avatar
Anyone know anything about a good place to get my block and heads done?
Old 07-26-2007, 04:33 PM
99.9percenter's Avatar
A 3.625 crank will get you 370ci. A 3.75 will get you to 383. Forget the sleeves.
Old 07-26-2007, 10:50 PM
Blownramair's Avatar
www.w2wpowertrain.com
Old 07-26-2007, 11:01 PM
Websy21's Avatar
I am going 408
Old 07-27-2007, 04:07 PM
LT1dude's Avatar
W2W is good, but they are expensive..
Old 07-27-2007, 04:46 PM
SantaCruz163's Avatar
396 + AFR 220s + D1 @~15# =
But, in reality it all depends on how deep your pockets are.
Old 07-27-2007, 05:21 PM
How much to do a lt1 block?
Old 07-27-2007, 08:27 PM
LT1dude's Avatar
I don't know but I know that when you look at their LS2 stuff, it is a lot more than most places, now I am not bashing them by all means, because their stuff could be absolutely bad, but then again, i am not about to spend the amount of money that they would want to do a bulletproof block for me, esp. when I can get it done a lot cheaper elsewhere with comparable results.
Old 07-29-2007, 04:53 AM
one way to find out... call them 248-589-1190... talk to one of the guys and let them know what your trying to do... then it depends how fast you wanna go and the quality of parts you can afford... they'll work with you...
Jay
Quick Reply: Good cubic inch for Procharger...
