Anyone use this zex turbo n20 kit
Im in the process of a single turbo forged 347 build. Im interested in using n20 or meth along with my setup. I found this new kit that injects n20 to spool the turbo and then cuts off with boost. Any reason to shut the n20 off when boost is detected. What do you think of this kit, its kinda pricey at over 700 bucks.
http://www.zex.com/
its towards the bottom of the page.
Alex
http://www.zex.com/
Alex
I have used N2O/Meth in my turbo cars for many years now. I have built my own kits as I am not particularly fond of the ZEX kits. Many have used them w/o issue but I don't particularly care for them, this is just an opinion. As far as the N2O/Meth itself I believe you will be very happy with it. You can build you one as well using Nitrous Express part #15302L and a Hobbs switch to cut it off at your desired boost level. You can use it during the entire run should you like just make sure that you tune for it. Take care and hope this helps.
Jim C.
Jim C.
