View Poll Results: Drive with broken oil pressure sender
With
6
60.00%
Without
4
40.00%
Voters: 10. You may not vote on this poll
Can I drive w/broken oil sender??
Well, I became a member of the "broken oil pressure sender" club.
Can I drive without til the new one comes??? From searching and reading on here it seems to just affect what the gauge reads. If thats all I can live without it for now. The reason I am asking about driving without it is, I have been without it for 4 weeks now and I am moving 1400 miles away on Tuesday and that would be the day it will come in. I would really like to give it a thorough going over before I leave.
Thanks.
Thanks.
Originally Posted by 2001NBMZ28
Just pick one up at your local parts store, or pay a little more at the stealership.
I dont understand the pole but all that keeps oil from blowing out is that little plastic diaphram....I would not drive it ....if that diaphram comes out your gonna loose oil fast and could ruin your engine....JMO
Originally Posted by motoo344
Is this the thing that everyone talks about when swapping to the ls6 intake? Why is it so easy to break, sorry for hijackage.
So what happens is, you have to slowly slide the intake back, and then make sure to loop the big hose over BEHIND the oil pressure snder as you go. Otherwise, it gets in front of the sensor, and as you slide the intake on back, it gets between the back intake and the oil pressure sensor, there is not enough space there for the hose IN FRONT of the sensor, so you end up breaking the sensor off. It's got a plastic body, and will break real easy.
You just have to be real carefull as you slide the intake back, and make SURE the hose goes BEHIND the sensor. IF YOU FEEL ANY RESISTANCE AS YOU SLIDE THE INTAKE TO THE BACK, STOP! 'cause you are probably about to brake the little bazdard!!
