BS3 users: A/F logged into VE table or correction
there is an O2 correction term that is generated from the desired A/F and the actual read by the wideband. You can either enable closed loop control based on the wideband or simply log the correction, as well as enable trim block based learning.
In either case, you can log the correction. Then replay your logs with the trace feature on the VE table itself and apply the correction to the actual cells of the VE table you hit.
Not automated unfortunately
Be aware, there are two tables based on RPM for positive and negative correction limits.
