Dyno numbers with the Cartek X-package
Old 05-18-2003, 06:46 PM
bspz28's Avatar
Default Dyno numbers with the Cartek X-package
As Most of you know my car been at Cartek getting a new motor installed I went with a new shortBlock with their stage II X-Package LS6 heads and their custom cam.
I just can't say thanks enough to the Crew at cartek They did an awesome job on my car. You guys are the best and THANK YOU
Now onto the numbers
With a short belt on the car and threw the Muffler it made
453 hp
409 tq
After I opened the cutout the car made
460.7 hp
417.7 hp
The car runs awesome. There is power everywhere I can't thank Cartek enough for building me a monster. I plan on taking it to the track very soon for some new ET's
Special thanks to Julio Dave Rich and Roy for giving me back a whole new ride .. I just hope my tranny will last for a few passes
Old 05-18-2003, 07:36 PM
Tire Smoking Tranny Blowing Director
Cool28's Avatar
Default Re: Dyno numbers with the Cartek X-package
So I know you took it to the track already . Glad ya like it man hope it runs great for ya
Old 05-18-2003, 10:26 PM
DONAIMIAN's Avatar
Hmm.... Thoes are some bad *** numbers, but I think you could get more out of it. I guess its the fact that it hasnt been broken in yet all the way. But to be honest thoes are some truly bad *** number from a heads and cam car. and you should see 460 through a muffler after break in
Old 05-18-2003, 10:29 PM
BIG PD's Avatar
are these numbers from a 346?
Old 05-19-2003, 12:51 AM
Restricted User
CAT3's Avatar
Would you mind giving a little more info. A stock short block can be punvhed, stroked and domed like hell. If this is 346ci, and all i would like the turn around time and more info-definately intersted.
Old 05-19-2003, 06:12 AM
Fahad's Avatar
Congrats..
What's your rear gear? & the transmission it's M6 or A4?
Thank you in advance
Old 05-19-2003, 07:18 AM
jfm
jfm's Avatar
Great to see you up and running,now go and crack off some 10s.
Old 05-19-2003, 10:20 AM
95Compta's Avatar
Congrats Pete on the AWESOME numbers. Can't wait to see that monster at the track.
To answer a couple of questions Pete's car is an M6 with a 12 bolt and 4.10 gears. I also believe the bottom end is stock and only the heads and cam were replaced.( but not 100% possitive )
Old 05-19-2003, 10:29 AM
JS
JS's Avatar
Badass Pete...
Good luck with the kerminator...
Old 05-19-2003, 03:54 PM
KF2KZ's Avatar
Congrats Pete, about time the Kerminator is together again. Now let's see those 10 second slips in the near future...
Old 05-19-2003, 04:56 PM
I can shift faster than you.
Jason99T/A's Avatar
Congrats Pete!
Old 05-20-2003, 02:48 AM
oOoLy's Avatar
Congrats!! on your awesome numbers
Old 05-20-2003, 04:02 AM
bspz28's Avatar
It's a stock block piston and rod motor 346 ci then only thing done is the timing chain. I had my stock one break on my original motor. Your best bet is to call Dave at cartek 908-317-4496 for more info on what I have and prices on what you would like
a Little info on my car here. I am running a 6 speed 98 camaro with a moser 12 bolt (4.11) gears Grotts for headers and a Mufflex Y-Pipe going threw a cutout and B&B catback. Direct flo lid takes the air in to a stock MAF without the screen and a cartek ported throttlebody. A port matched LS6 intake is also on the car.
Thanks again to the crew at Cartek for buliding me a sick motor
Old 05-20-2003, 05:21 AM
BIG PD's Avatar
are these RWHP numbers or motor numbers? what cam and what heads? specs please
Old 05-20-2003, 10:40 AM
bspz28's Avatar
These are RWHP SAE corrected. I am running the Cartek Stage II X-Package heads and cam. I'm not sure of the cam spec's I belive it's a 224/228 cam ..
Old 05-20-2003, 10:55 AM
BIG PD's Avatar
congrat i think that's the most hp for an N/A heads and cam 346 then, wish i could use their dyno now go run some mid 10's like a car with that power should be!
Old 05-20-2003, 11:52 AM
JS
JS's Avatar
Why should it run 10's,just because u say it should big?
Theres ALOT more to runningt 10.50's than big hp.
Weather,traction,suspension,etc..
Its not as simple as U make it sound.
One things for sure BIG,Pete will run well.
Old 05-20-2003, 11:56 AM
Restricted User
CAT3's Avatar
Pete, I understand the info thing and appreciate your help. Good-Luck and enjoy the car. Thanks for helping make the decision to go H/C/I!
Charlie.
Old 05-21-2003, 10:07 AM
JayLS1-327's Avatar
Very nice !
Good luck with it !!!
Old 05-21-2003, 05:11 PM
robertbartsch's Avatar
Great numbers!
Can you provide some specs on the cam?
