hooker y pipe to stock I pipe loose fit any fix?
the slip on fitting between Stock I pipe and hooker offroad Y pipe fits loose I don't want to weld any flanges just use clamps any fix?
Re: hooker y pipe to stock I pipe loose fit any fix?
Go to Harbor Freight and buy a tailpipe expander, I paid 10 dollars. I had a similar problem with Borla catback and Hooker ORY. If you were any closer I would let you borrow mine. Good luck.
go to your local auto parts store and buy tailpipe wrap for high temps. wrap the joint and buy a 3" band clamp from say speed inc or whereever and this will seal your leak. youll have about $12.00 wrapped in it but it works
