HPTuner bin for 224/228 + AFR205 + M6?
Old 07-28-2007, 04:30 PM
zain98's Avatar
Default HPTuner bin for 224/228 + AFR205 + M6?
Doing my heads and cam install myself this weekend with jmilz28. I've got HPTuners warmed up but am looking for a bit of assistance with tuning.
I plan on doing this myself from scratch with what I am learning. However, this would be easier if I had something close to start from. Would anyone be willing to help a broseph out?
Thanks much,
Zain
Old 08-01-2007, 12:51 PM
jmilz28's Avatar
bumpo for a humble request...
Old 08-01-2007, 12:55 PM
helicoil's Avatar
Default Afr 205 A4
+1 Looking for similar info as I have a similar set-up 224/230 113 ICL with the AFR 205 heads but an automatic.
Thanks,
Old 08-01-2007, 12:57 PM
98Camarod's Avatar
Have you guys checked the on hp tuners for the file?
Old 08-01-2007, 02:53 PM
jmilz28's Avatar
Yep, sure have. Nothing similar comes up.
Old 08-01-2007, 05:18 PM
WS6 GreeN's Avatar
A couple more things people may need to know is are you going to run it in speed density? Also did you change out the injectors?
Old 08-11-2007, 06:00 PM
jmilz28's Avatar
Nossir, no SD, MAF. Factory injectors on '01 SS.
AFR 205s
224/228 mamo combo cam
stock LS6 intake + TB
Kooks LTs (1 3/4s) + Kooks ORY
Factory Dual dual cat back
Anything else that would be helpful to know?
Old 08-11-2007, 06:52 PM
WS6 GreeN's Avatar
If I wasn't running SD, you'd be more than welcome to my tune, which is a 226 cam but there shouldn't be too much difference and it would be a good starting point. Might be hard to use someone else's tune if you don't have a wideband to verify things with but you probably knew that already.
Old 08-11-2007, 09:45 PM
zain98's Avatar
any tune close would be great. i realy would like to see what peeps with close set ups are running.
Old 08-11-2007, 10:00 PM
02SOMWS6's Avatar
Thanks much,
Zain
My bin file would be perfect cause I have the same cam but something about paying someone top dollar to tune my car and he spent more than half the day tunning on the street and the dyno then just to hand that over ......... Your car will run untuned with that cam, it's not like that cam is so radical that it has to have a tune to run. My set up made 452rwhp and 408rwtq threw a 12bolt with 4.30 gears and a heavy steel driveshaft.
Old 08-11-2007, 10:10 PM
zain98's Avatar
Im not looking for the one size fits all tune. i want to see the changes in the tunes so i can make my start in the tunning process.
Old 08-13-2007, 08:38 AM
jmilz28's Avatar
Understandable. I don't know how well that would work anyhow, since zain is using stock injectors. My newb head tells me that would throw off the whole A/F thing?
Zain also has a wideband in hand.
