Cat(s) rattling on my 99... i think
I've been noticing for a while a rattle coming from my exhaust on my 99 Z. I first thought it was a heat shield hitting my hooker catback exhaust. Ive checked every inch of the exhaust multiple times. I finally thought i had it narrowed down to the joint between the ypipe and the ipipe. I bought a nice 3 inch stainless band clamp and tore off the stock clamp and tightened it up perfectly. Unfortunately, it still has the same noise. It rattles most noticeably as you let off a rev at idle. If you hit the exhaust from underneath it rattles, but i cant pinpoint it. It seems like its just coming from everywhere up towards the ypipe.
Is there anything else it cold possibly be. I crimped those little rings on the o2 sensors down cause i thought they may be rattling, so its not them either.
My questions are:
1 About how much would it be if i just took it to a shop and said replace my cats and clean out my ypipe (im afraid cat bits or maybe the screen may be shoved back in there somewhere)
2 Would it be cheaper to just delete the cats by buying an ORY? What options are there for the 99 style ypipe (as opposed to the 02 style).
3 Is there anything else I am missing that this noise could be? Is there any way to test for a rattling cat besides removing the ypipe?
My questions are:
Originally Posted by Loochy88
My questions are:
2. Yes it would be cheaper . You can mail your computer for what is called a mail order tunethat should take only a weekdowntime forthem todelet the 02s and do whatever other tuning . This alone will net you more power withthe addition in flowwhich is also one of the first steps in mods on your ls1 .
3.Could be bushings or something . Every car ratttles after time jsutone ofthose things . You could replace all thebushings ( prothane makes a kit ) though it does take time.
My advice just go ahead and put a good exhaust system and it will sound well enough for you to forget about whatever soubnd is bothering you .
Originally Posted by snake charmer
1. A shop would charge you a lot of money . Enough to have pretty much whatever aftermaket /performance exhaust .
Besides the bassani ORY, what other options are there for a the 99 style cat setup, that would connect to stock style manifolds?
Originally Posted by 98dropta
the honeycomb material inside your cat could be all busted up and bouncing around in your cat......happpened to me........
thats what im figuring is going on. did it sound like marbles in a can when you let up on the accel. thats more or less what mine sounds like at idle.
well i plan on doing an ory, but no headers. i dont want to fool with headers on this car. i had enough fun with them on my last one. what options are there for ypipes with stock style manifolds on a 99.
